NE Ohio 911's Avatar
Help before this drives me insane.
I replaced my master cylinder last winter. Everything has been fine until a month ago when I started hearing an intermittent hissing sound coming from behind the brake booster. After reading some posts on PP, I replaced the vaccum hose, check valve and grommet but it didn't fix the problem. If I plug the hose the hissing stops. I guess the only thing left is the seal between the booster and master cylinder? Brakes are fine and the hissing does not change when engaging them. Any input would be apprecited.
Sent from my SM-G965U using Pelican Parts Forums
Doug
1984 Carrera Coupe
Old 11-09-2021, 05:36 PM
That booster needs rebuilding, or replacement. Go to a reputable rebuilder or you will not be happy. Or, just buy a new one.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-10-2021, 07:08 AM
Diagnose this properly before replacing something expensive like the booster.
Two things you can try to isolate where the "hissing", which we assume is leaking air, is coming from.
1. A cheap mechanics stethoscope - move it around until the sound is loudest to find the leak
2. Soapy water in a spray bottle - spray the area and look for bubbles
If you are referring to plugging the short hose near the booster, by removing the end that connects to the inlet on the chassis, and the hissing stops, my gut reaction would be something is wrong with the check valve. Your finger is acting as the valve instead of the actual check valve. Ensure it is installed correctly. It's hard to mix up but not impossible.
Old 11-10-2021, 07:58 AM
brshap's Avatar
Hissing is a classic sign of a booster on it's way out.
1984 Carrera 3.2 Targa
Old 11-10-2021, 08:59 AM
Use a vacuum line and put it up to your ear. Cheap man's stethoscope.
Old 11-10-2021, 09:15 AM
Thanks for the suggestions everyone.
Doug
1984 Carrera Coupe
Old 11-10-2021, 11:26 AM
