964 fender on 911SC
I believe the answer is no, but can a fender from a 964 be used as a replacement onto a 911SC?
1981 911SC |
Insert Tag Line HERE.....
The short answer is... sure can..
Marc |
I did on two cars. Yes.
I’ve done more research since I made this post and it seems that there will be no hole for the antenna on the passenger side. On the drivers side the gas cap area is different. And there may be some mounting tabs that need to be trimmed.
1981 911SC |
piece as opposed to the welded in metal piece on an SC. However the later fender with the plastic piece can be made to work. Look up diagrams for later fenders in PET. If you find a fender, ask to check the gas filler area for the plastic piece.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
I removed the filler pocket from my SC fender and after grinding off the spot welds and removing the old steel flange from the original fender the pocket slips right over the bolting flange on the 964 fender. I just had to drill four bolts in the old bucket and bolt it in. It was a perfect fit. I would have plug welded it but the paint on the fender was a perfect match so I just went with it.
Fenders from 74-89 are all interchangeable, however antennas did switch from drivers side to passenger side depending on year.
Cars with AC have the drier cartridge at left mounted at A pillar. This reduced room for the body of an electric (Hirschmann) antenna. So cars with order list with AC and electric antenna had the antenna mounted to the right. Happy to learn more if I’m wrong.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Flojo..The drier is in the wheel well and the manual antena is in the door jam..
So manual antennas were used on DS. till 1980(depence if Euro OR US).The location of the hole was a little different on 1978-79 on the right fender. Also it was and option if the clients wanted el.antena or manual.After, all antennas were on the PS electric.. Electric antennas were never on the left side... Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 11-15-2021 at 10:26 AM.. |
