If so, it's time to have the DME ECU tested! |
Still going to see about getting co2 checked. Thanks for all the inputs, I've learned a ton. |
Hi,
Happy New Year. Bit of a thread resurrection but I have a quick question as finally the week has come where I can take my car to a local specialist. Is it safe to drive the car with the ICV disconnected when I take it to the garage? Reason for asking is that I have unplugged the valve, manually set the vane position to part closed and I can get a buttery smooth idle with no pulling - this feels a lot safer than having to ride the brakes and deal with the on/off jolting I experience when the valve is plugged in. I plan to leave early morning to avoid traffic but being a touch paranoid I don't want to do any other engine damage from running it too rich/lean or risk it cutting out mid drive (I've deliberately set the idle slightly faster at around 1k RPM). |
I got the car to the garage with no issues.
Unfortunately, the garage (Impact Bumper specialist) believe the ECU is faulty. Big bills pending |
Where are you located, U.K? Here in the U.S. it'd be pretty straight forward to get the ECU tested and if required repaired.
Hi,
Yes in the UK - seem to be a few repair shops but not sure on who is reputable. I've been doing some research about alternatives to the Motronic system as there are few available, it appears CANEMS have discontinued their direct replacement. Are there any other alternative ECU should I not be able to get it repaired? |
sibebp,
Any Motronic box can be repaired. I've had boxes on the bench that were submerged in water for extended periods of time or had internal "fires" and even these were brought back to life. In terms of economics I don't see any alternative that would come even close to getting the DME repaired. Even a homebuilt Megasquirt would set you back more than buying a good used DME outright. And that is before labor... |
That's positive - I wasn't sure if Motronic repair was a dying art. Will do some research on some of the UK forums.
Pretty sure you'll find a good pro in UK. Otherwise, we have decent people here in France too, but you'd have to ship your box across the Channel and with Brexit and all, that has become less than easy.
| All times are GMT -8. The time now is 01:45 AM. |
