3.2 Surging Idle
Hi,
Firstly, hello, I recently joined having bought an '88 G50 3.2 Sport this year. After some advice on an issue that's driving me crazy.
I have:
My suspicion is that it is a mix problem, caused by a vacuum leak (I cant find anything obvious in the ICV area where I've been working) or potentially the car just needs the mix resetting but I am not sure. Speaking to a garage they are suggesting the AFM might be faulty or perhaps the ECU given its linked to temperature rises; the garage has a good rep but I am struggling to understand why replacing the ICV would now expose issues in those parts, a vacuum leak or setting the AFM up again feels more probable? Any ideas on what to check and in what order? The garage can't fit me in until mid-Jan so its a long wait with a relatively new car ![]() Thanks in advance. Last edited by sidebp; 11-10-2021 at 11:29 PM.. |
Welcome to the forum and congrats to your 3.2.
As far as unstable idle do a search here and you will find lots of very informative threads dealing with this topic. In general you're correct that intake leaks affecting mixture at idle account for the vast majority of poor idle performance. Before you adjust anything it makes a lot of sense to track down any potential intake leaks. The main culprits are: - deteriorating rubber hoses on the intake - brake booster vacuum supply - intake runner gaskets Then it comes down to properly functioning sensors (CHT, IAT, AFM) that tell the DME how much fuel to inject and correct adjustment of idle mixture and throttle stop. Unfortunately, once someone messed with the adjustments to mask a problem you have to go back to the basics. Cheers, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Try turning the idle speed down to 880 first.
Sounds like my ‘87 3.2. Behind the throttle body is a real tight mess of vacuum lines including the large line that goes to the vac brake booster up front, the venturi assy, and about a dozen clamps.
Remove the air filter box, air blower and ducts, and look around at all the lines for cracks, loose clamps, etc. Most importantly, check your rubber fuel lines. |
Idle Valve Testing, post #20, Bench testing Carrera Idle Control Valve
Dave |
Did your garage checked the fuel mixture??
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Can't get an appointment til mid Jan. Looking for another garage (this one has a good rep though hence the delay I guess)
Vacuum leaks!
Entire crankase venting system, intake needs to be checked. Oil cap to brake booster and cruise control . The little rubber tees behind the air cleaner that connect to nylon vacuum lines are cheap. Throttle body has a couple of vacuum lines so does fuel pressure regulator. There should be a diagram |
Search how to adjust idle on the 3.2 on this forum. There should be a picture of the socket you need to jumper mounted on the left side of the engine compartment. I'm in agreement with John Walker on this... adjust your idle first.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
![]() ![]() there is a relay for the plug and idle adjustment but wire will do Ivan
It seems you're already far down the road of adjustments. However, contrary to some opinions here I'd always question why an adjustment is required in the first place. More often than not there is a primary problem that developed over time or suddenly (e.g. intake vacuum leak, fuel pressure or fuel delivery issues, condition of ignition components, worn AFM) resulting in poor running. Idle is particularly affected because intake leaks (un-metered air) have the biggest impact at idle.
Adjustments are then made in an attempt to compensate. However, if the underlying issue is not subtle the adjustment itself runs out of range or won't be effective. I would always go back and confirm basics check out before messing with idle adjustments: - intake vacuum leaks - fuel pressure and fuel delivery - general upkeep (plugs, rotor, wires, valve adjustment, etc.) - sensors (CHT, AFM, IAT) Good luck and keep us posted on progress
here is a guide from Porsche 911 manual how to adjust fuel mix....
Hi Ivan,
Do you have more info about this relay, My guess is the switch shorts jacks B and C together, but what do the green and red LEDs indicate? Did you make this?? Is this connector used for anything else? Cheers Ray |
You can pop the top off an old black relay and simply push the top contact down with your finger to do the same thing, if I remember right.
Dave |
Thanks Last edited by sidebp; 11-12-2021 at 01:09 AM.. |
that relay is a tool for 944 testing ..it is simple tool i got from the dealer back in the 1980`s...here
![]() i liked the idea ..again wire does the same Ivan
