Nitrous
Wondering if there is any company doing nitrous oxide kits for 911's. I have experience of nitrous when I fitted a 150hp set up onto my 289 s/b Ford - lots of fun but has anyone got a set up and if so how did it perform. My engine is a 2.4 on Webers so it's fairly basic.
Old 12-08-2021, 08:39 AM
It's a 914 ...
stownsen914's Avatar
The 2.4 motors aren't necessary the most robust. Would be curious to hear if anyone has had luck NO2'ing one.
Old 12-08-2021, 06:39 PM
Bill Douglas's Avatar
They are quite expensive engines to blow up.
Old 12-08-2021, 08:42 PM
While I definitely see the appeal, it’s not something I’d risk with a 911 motor. Especially a 2.4
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 12-09-2021, 12:04 AM
If you decide to go with it...I recommend Zex..the safest nitrous kits. (a/f ratio is safe)
I don't have a kit on my 911's, but I installed a 75 shot(hp) Zex kit on my 98 Prelude.
Have gone thru many tanks and it hasn't harmed the engine one bit. I also use a tank heater, to keep the pressure up, and a remote bottle opener so that everything can be done from the seat.
It's fun, but around here, the nitrous is getting expensive. Was $25/fill, now it's $55
Zex.com
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 12-09-2021, 04:30 AM
I have put nitrous on many mopar small and big blocks with very good results when using modern EFI along with it to control timing etc... One of the most important things is to assure ring gap is appropriate for the application, unless you are willing to tear the engine apart and start at the rings i would not suggest adding nitrous. I agree with the other comments, nitrous has gotten expensive and in my opinion is more for the 1/4 mile, a 911 of any area is not built to just go fast in a straight line and too expensive to experiment around with.
Old 12-09-2021, 05:02 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Does it really stress the engine more than a turbo would? Sounds like easy HP. Maybe not ideal for a 2.4 but a 3.2 yes.
Chris
Old 12-09-2021, 10:01 AM
Nitrous carries a terrible stigma. Most of it is undue.
If a person follows the rules..it's safe. The Zex kits work differently to keep the a/f mixture correct.
They are set-up to only spray when at wot. Spraying at less than wot...can damage the engine.
Unlike the movies...not necessary to 'push a button' for the extra horsies.
Your foot does the whole job.
98 Honda Prelude
22 Honda Civic SI
Old 12-09-2021, 10:21 AM
gtc gtc is offline
abides.
gtc's Avatar
Don (haycait911) had a nitrous setup on one of his cars... i think he has posted about it before. Do some poking around and you should find something about it.
Graham
1984 Carrera Targa
Old 12-09-2021, 12:18 PM
I changed mine to air filter injection. Spreads the mixture out better. (line going into filter)
98 Honda Prelude
22 Honda Civic SI
Old 12-09-2021, 12:39 PM
Obvious problem with a boxer engine is the physical layout which precludes just shoving a pipe up the air cleaner. I expect I shall have to drill and tap each inlet port for the injector and consequently I shall have to make very sure the amount of nitrous is absolutely correct with regard to quantity and balance to the additional fuel. One point in my favour is that at WOT the Webers although being correctly tuned, do hurl in quite a good amount of fuel. I wasn't too aware of your recommendation of ZEX, I have emailed them for information and I note they are part of the Edelbrock family (just read the Edelbrock story - most interesting) so I would hope their pedigree is very good.
Most folks I know say nitrous for a Porsche? you must be joking, but I have always been a little left field so we shall see how this project transpires.
Old 12-09-2021, 12:55 PM
[QUOTE=ignatzcatz;11542215]
Those folks have watched too many 'Fast and Furious' movies.
Some see it as an explosive liquid flowing into your engine...while all it is doing is condensing the air.
Keep us posted.
98 Honda Prelude
22 Honda Civic SI
Old 12-09-2021, 01:09 PM
I think you would have to make your own kit and install a nozzle in each manifold with Webbers.
It can be done, but you are going to have an issue breaking head studs.
And what is the goal? You still won't win a drag race.
Derrick
Old 12-09-2021, 01:43 PM
^^^would you say no to 100 extra hp on your Porsche?
He is not talking about making it only go in a straight line.
98 Honda Prelude
22 Honda Civic SI
Old 12-09-2021, 01:45 PM
100HP for how long? 30, 60, 90 seconds just to break a head stud.
Is he going to track the car and push the button down the straight?
I don't get the risk to reward on this idea.
Derrick
Old 12-09-2021, 02:25 PM
^^^ There is no button to push. Think of it as a turbo that only kicks in at wot.
98 Honda Prelude
22 Honda Civic SI
Old 12-09-2021, 02:28 PM
It's a 914 ...
NO2 is for that very thing though, no?
Old 12-09-2021, 07:03 PM
Hmm... a 2.4 in a 356 - hat's off, sir, a really bytchn combination. Which leads me to ask - which tranny? That may prove to be your "tentpole" item. A mag case 901 might not be happy with that kind of power. A mag case 915 would be happier. An aluminum case 915 would be happiest. You would probably peel an original 356 tranny like a banana with that kind of power, but you are probably there already, so that's why I'm assuming one of the afore mentioned 911 trannies is being used.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 12-09-2021, 08:03 PM
Im assuming this would only be done in a non CIS setup given that a good fart can pop the airbox,
Old 12-10-2021, 12:17 PM
Nice looking motor. And, car. Can we get a full pic of your 356 ?
Old 12-10-2021, 01:39 PM
