shahram's Avatar
Parts for Zenith Carbs
Does anyone know where to get parts for Zenith carbs?
Old 11-23-2021, 03:56 PM
1QuickS's Avatar
try eBay seller "Alfa1750"
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 11-23-2021, 04:10 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Alfa1750 has lots of new parts. If he doesn't have what you need we have everything else.
Thousands of parts from butterflies to complete housings.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-23-2021, 05:06 PM
shahram's Avatar
Thank you guys. I try the ebay seller alfa1750 and if i don’t find the parts i will contact Henry.
Old 11-23-2021, 07:57 PM
I got most of mine from alfa1750 and parts Classic (with a K). If I knew Supertec had the parts I may have started there.
Be aware the so called zenith rebuild kits contain a lot of pieces that fit poorly or are just wrong. You will want to supplement the kits with the correct o-rings, gaskets, etc. to eliminate the possibility of air or fuel leakage due to poorly fitting parts. Otherwise proper tuning will be a challenge.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 11-23-2021, 08:48 PM
7783911's Avatar
Joe curto (google him) rebuilds and has parts, did some for some of my other cars in the past, excellent work
Old 11-24-2021, 03:32 AM
