Upshift Light Mystery
I've had my '84 3.2L for about a year and a half (125K miles) and, in that time, the upshift light has never worked ... not even once. I'm driving around my neighborhood this afternoon and - all of a sudden - the upshift light starts working. I realize that many will view the operation of this nanny light as a curse rather than a blessing, but I like things to work as intended. Any ideas as to why this light would magically start working?
The signal comes from the DME brain (it does on my 88). It stopped working on mine so I sent the DME brain back to ECU doctors and they fixed it under warranty. Could be the connection on the back of the tach or the light bulb in the tach. Any chance you recently tightened these or maybe a good bump got it working.
I actually like the light and like that every component on my 88 works. The upshift light not only comes on under mild acceleration for better gas mileage, but it also comes on at max RPM under heavy throttle.
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
Porsche Addict
I ignore the one on my tach.
I find it annoying.
Lawrence - 1986 911 Carrera Coupe Grand Prix White 1959 Land Rover Series II 1962 Volkswagen Sedan Ragtop 1959 Porsche 356A Coupe 1971 Porsche 911T coupe |
![]() I just ignored my shift light for several years. I too like everything to work as designed, or better. That shift light was just a government mandated fuel economy stupid idea. I just LOVE having a volt meter in the spot where the shift light was. A volt meter is a million time more useful than the shift light. I prefer my calibrated temperature gauge as well. Knowing an actual temperature at a glance and not just a mark on the gauge is comforting.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Slippery Slope Expert
I always thought they encouraged short-shifting and lugging.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.” |
Mine worked, then stopped working for a little while when my tach wiring was wonky, then started working again when I had the the tach wiring fixed.
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
Porsche decided to go with the shift light and not a stupid vacuum gauge. And for sure, if one followed the shift light suggestion, driving the 911 was as much fun as driving a 40 HP VW bug. At least Porsche got rid of the idiotic 85 MPH speedometer with the big red 55 on it as soon as the law was changed. I remember the bad old days of 55 MPH national speed limit. Just a few weeks ago I cruised past a state trooper, with my radar detector alerting me of radar, while I was driving 80 MPH. That was the legal and posted speed limit. It was somehow very satisfying to roll by at 80, knowing I was not even bending the speed limit.
R&D guy
Location: the border between the states of inebriation & confusion
I actually like the upshift light on my '87 3.2, so much so that I disassembled the tach and fixed mine. Well, not just because I find it useful but more because I wanted everything in my 911 working. As to why one would not be working and then start working, I can only guess:
I actually want to disable the shift light... anyone know which wire to pull off? Is the bare wire on the multi wire connector the shift light? Or pull out the bulb?, I can't seem to find access to the bulb. 1986 Carrera.
In my 10 years of ownership the shift light seems to follow the moon and the tides. It amuses me when it works and I forget about it when it doesn’t.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
-Mark B. Hardware Store Engineer 1988 911 - 3.6 1999 SL500 - Gone 1995 M3 - LS2 - Gone 1993 RS America - Gone |
Mine seemed to work accasionally in the early Spring and late Fall, when it was cooler out. Never in the summer heat. But I haven't seen it at all in the last few years. One of life's little mysteries!
Roger 1968 sand beige 911 Normale coupe #11830091 1984 metallic moss green with champagne interior 911 Carrera coupe 2012 silver with red interior Boxster |
That light is driven by two inputs
The input from the DME indicates the rev limiter The fuel economy function indicates high intake manifold vacuum, but only above approx 2k rpm I disconnected the economy function years ago but it still indicates the limit |
I love the fact that you guys know this stuff!
