Muffler Strap too short by 3/4 inch
I am trying to install a Dansk 2 in 1 out muffler with 70mm chromed tip on my 1979 SC
I got the IRO strap Porsche # 901 111 157 04, but it comes up an inch short, and it isn’t on the car yet. Help desk here said it is the right part. Anyone else have this problem? I guess I can get a longer bolt, but would like it to fit.
Old 12-09-2021, 10:14 AM
Full Send Society
Have you tried clamping them together to stretch or seat them better... sometimes they need a bit of force...
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 12-09-2021, 10:24 AM
Perpetual Reassembler
2jmotorsports's Avatar
Mine are super tight as well. I have to zip tie them closer to get the threads started. Takes a little practice.
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 12-09-2021, 10:27 AM
^^^ Same here...had to draw them up together.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 12-09-2021, 10:38 AM
The picture is after stretching the clamp.
Old 12-09-2021, 11:24 AM
theiceman's Avatar
longer bolt ??
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 12-09-2021, 11:51 AM
47silver's Avatar
clamp
make sure that the lip on the bracket on the support is under the lip of the muffler.
1975 911S Targa
Silver Anniversary Edition
Old 12-09-2021, 12:45 PM
Still here
pmax's Avatar
Strap’s too loose.
Old 12-09-2021, 12:50 PM
Eng-o-neer
Tremelune's Avatar
Yeah, I just did this and it sucks. I used long bolts to close it and bend it into shape...Once I got it on...I just left the long bolts in instead of replacing them with the short bolts as I had initially planned...I think I may have stripped one, too. Good times.
Is the OEM version better...?
Old 12-09-2021, 01:32 PM
Longer bolts work fine, a non-problem really.
206 637 4071
Old 12-09-2021, 01:41 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
I had this problem when first installing the Dansk 1-in-2-out (84 mm outlets) in my '87.
I found that by playing with the strap locations and "preforming" the bends I was able to get the OEM straps to work.
I also agree with the other posters regarding longer bolts - the bolt in your photo looks shorter than the one used to secure the muffler in my 3.2.
One other point: Are you sure you received the correct strap part? It is notable that for my 3.2 there are (2) different straps used: 930-111-175-00 (passenger side) and 930-111-159-00 (driver's side), per the Porsche parts catalog.
Old 12-09-2021, 02:16 PM
Cory M's Avatar
Common problem with those straps, longer bolt needed
Old 12-09-2021, 02:39 PM
Muffler Strap BOLT too short by 3/4 inch
fixed it for you, LOL BTDT
Old 12-09-2021, 02:53 PM
I guess that is what you can expect when buying the IRO $15 muffler clamp, instead of the $75 NORMA one. But $2 and two 3 inch bolts did the trick, so $32 v. $150, I think I came out ahead. It is a shame that our host told me he had never heard the clamp was too short, the forum comes through!
Old 12-10-2021, 08:36 AM
Dansk mufflers are fatter than stock ones, and their lips are wider. Put the bolts inside, toward the engine or they will damage the valance next engine removal.
206 637 4071
Old 12-10-2021, 08:54 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
wrong bolt. Stock is a Hex. I use a longer one to get it tight then swap in the stock bolt.
Old 12-10-2021, 09:16 AM
Could be the wrong strap, There are two sizes, I bought two used from a Pelican member and one was too long to tighten up on my 77 with backdated muffler.
Old 12-10-2021, 04:53 PM
I seem to remember cinching it up with a longer bolt, then clamping it somehow (like with visegrips), removing the long bolt, inserting the OEM bolt. Large pain in the neck.
Old 12-10-2021, 09:17 PM
Jeff Alton's Avatar
there are multiple part numbers for the straps. Ensure you have the correct ones for your application. Consult the PET diagrams to be sure. Longer bolts may or may not be the correct solution....
Cheers
www.turn3autosport.com
Old 12-10-2021, 10:04 PM
