Headlight AWG wiring gauge
Hello
Trying to fix my headlight wiring. I´m a little lost with the AWG gauge system. Do you know the wire gauge of the factory wiring between the fuse box and the headlight housings. Thanks Miguel 911 Carrera 1985 |
Common guys. I know it´s a silly question but I´m about to order some wiring connectors and its especifications are in AWG. I´m from Spain (Europe).
Thanks |
ROW '78 911 Targa
16 AWG is very close. 18 is smaller, 14 is larger.
The manual calls out 1.5 square mm as standard. If you have to buy AWG, Dennis is correct. 15 AWG would be almost exact, but is basically not available. I always use one size larger, just because I can.
16 AWG will work fine. If you are in Europe, look for everything at 1.5 square mm. Cheers, -Dave
-Dave in Minnesota 96 C4 Cab, 85.5 944 82 SC Targa SCWDP #0023 82 928 67 912 60 T-5 B Cabrio |
put a HL relay in while your at it
All the wiring and sizing you need on the original wiring diagram.
In mm2 (not AWG) http://www.911c1.de/porsche/Schaltplaene/plaene1-10_carrera_32.pdf Regards, Frank
__________________ 1985 Carrera 3.2 |
always listen to Timmy..electrical guru
