AMPs required to run 12VDC dash clock?
Trying to run Porsche dash clock off of 120 converter.
Anyone know? Thank you! |
I'd expect a couple hundred mA max.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
thank you!
Connect an ammeter in series with a battery and the clock and measure the draw. Or measure the clocks resistance and do the math
1966 912 to 2.7 Frankencar |
Ayo Irpin, Ukraine!
https://www.vdo-instruments.com/media/instructions/TU00-0755-0000002%20Cockpit%20Int'l%20Analog%20Clock%20Data% 20Sheet.pdf
Probably in this ballpark.
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
Author of "101 Projects"
So, depending upon the year, the older clocks (like the ones on a 356) have a coil in there that winds a mechanical mechanism. This then winds down for about 5-10 minutes. When it gets to the bottom, it closes an electrical contact and zip - winds it up again. I have one inside of an old piston on my desk - powered by a AA battery. It can last for months like this.
The newer ones are a bit different, but they still draw almost next to nothing... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Wayne. I just made two of the piston clocks for my brothers for Christmas gifts!! Had one from a 77 and 88 911 they fit perfectly into an older 914 cylinder I was grateful to get from MEpstein here.
like all of us, I had literally dozens of those plug in transformers that go to every conceivable gadget... I just wired them up....work perfectly! 12 v , 1 amp. BTW those VDO clocks are some of the most accurate movements I have ever seen . |
We need pics
I had an aftermarket alarm installed on my ‘73 911. It would go off for no apparent reason. To the alarm installed quite a bit of diagnosing to figure out that the clock drawing current was the culprit.
He put some gizmo on the clock to solve the issue. Unfortunately, the clock became unreliable. Replaced it with a newer clock.
Sergio The GT Lid Whisperer PCA 42yrs - National DE Instructor / Ex-RGruppe #197 '19 718 Cayman S (9th Porsche/1st with PDK) '14 Subaru Forester XT (Porsche support vehicle) |
here ya go... love this (originally posted by another pelican!)
Coram Deo
An SC clock takes about 1/10 of an amp intermittently.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
I need a working clock.:/
im pretty sure last time i did a parasitic drain test the battery was drawing about 12-15 ma or so and the clock was the only thing drawing power...
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
