Jameel's Avatar
Who machines 915 cases?
Unfortunately Wevo isn't doing it anymore. I know about CMS. Are there other's out there who do the work? My main case races and final drive case races are both spinning.
Old 12-16-2021, 04:36 AM
AskewRSR's Avatar
Call Tom at Carquip in Colorado.
1965 911 Vin 1249 Slate Grey
1969 911 Golden Green 2.0 Twin Plug
1971 911 S Gold Metallic. Peter Gregg
1974 911 RS Euro Metallic Blue Gold lettering
1991 Brumos 3.6 Turbo Pikes Peak Zwart Motor
Old 12-16-2021, 09:01 AM
gearhead
Brian Copans, at BMC and Gee in Ohio can do it for you.
Old 12-16-2021, 10:06 AM
(man/dude)
Jonny042's Avatar
I found out the same when I needed a set done. Wevo seems to be slowly going into retirement (unfortunately). I think the kidney shaped single piece insert was the optimal solution but sadly no longer an option.
So, plan "B" was CMS. I was happy with the service provided by CMS. Highly recommended. I also purchased a single piece bearing retainer and a billet side plate from them. Wevo parts are really nice but one-stop shopping at CMS was convenient.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 12-16-2021, 10:09 AM
911 - 915 Getriebegehäuse in verstärkter Ausführung für Porsche - Neu im Programm - Albert Motorsport
Not cheap, but you get what you pay for.
Old 12-16-2021, 10:10 AM
Jameel's Avatar
Thanks everyone! This gives me a good start.
Old 12-16-2021, 10:28 AM
I spoke with Wevo a short while ago, and although they are not fixing cases sent to them, they do have units in stock that they are selling. Otherwise CMS is very reasonable.
Old 12-16-2021, 03:33 PM
Jeff Alton's Avatar
Dan Barnes. @danbarnes702 on instagram. www.danmfg.com
Cheers
www.turn3autosport.com
Old 12-16-2021, 09:31 PM
evan9eleven's Avatar
Someone should take over doing the Wevo inserts, or maybe take over Wevo.
I had TwinSpark in Holland machne in a Wevo insert for me a few years ago. It cost, but I’ll never worry about those bearings ever again. Or anything else I went over-the-top on with that gearbox.
(Sorry this doesn’t help the OP in Iowa. Good luck.)
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 12-17-2021, 01:56 PM
kevingross's Avatar
You cannot go wrong with CMS. I use them regularly, they've never let me down.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 12-18-2021, 10:43 AM
gearhead
I spoke to Hayden recently and Wevo is not going anywhere. The machinist he used for the case repairs and inserts retired, so he decided to just discontinue certain products.
We originally developed the insert with them many years ago (like 20) and I’ve considered bringing it back since he’s no longer doing it. I just haven’t found a machinist that I want to work with on it, yet.
Old 12-18-2021, 11:24 AM
