Does anyone have a detailed schematic of the Carrera 3.2 Alarm Control Unit?
Title says it all. I'm looking for a detailed schematic of the Carrera 3.2 alarm control unit. I've done some searches and come up empty; the representations I've seen are superficial (look, there's logic inside!). (The why: I am just curious.)
If one is not available - if someone has a dead ACU that they would be willing to send me, I'd be interested in opening it up to trace the circuit and draw a schematic. Assuming, of course, that the unit can be opened without destroying it and doesn't have the circuit board gooped, IC numbers removed, etc. Thanks, Dave |
I have a non working one that i can send, if i can find which box it's in.
Will check today and PM you. |
alarm module
![]() ![]() ![]() I think this is the alarm module; removed when i added keyless entry. |
Thanks - I responded to your PM.
Looks like a lot of the old diode-logic going in there. I would be interested in the schematic if you draw one up from the pcb.
Side question : did cars that did not come with the alarm unit always have the alarm unit wiring harness ? I recently ripped my front blower out in search for this harness to connect a gos tracker but could not find the harness where it is supposed to be if you follow the porsche wiring diagram (my car is a 1985 Carrera)? Sent from my iPhone using Tapatalk
__________________ 1985 Carrera 3.2 |
Dave |
I don't know the answer on the harness. |
Dave |
