WP0ZZZ's Avatar
PMO EFI Throttle Bodies vs Alternatives
I've noticed that PMO is making its ITBs for EFI in a dark finish which I find quite attractive. Is there any data about how these ITBs perform compared to other alternatives? I imagine that AT Power's shaftless ITBs perform better, but by how much?
https://www.youtube.com/watch?v=Iyl57J_-R8U
📸 https://www.instagram.com/porsche.tech 📸
Old 12-14-2023, 10:57 AM
I think that the shaftless are also a different price category
1976 914
1986 951
Old 12-14-2023, 01:10 PM
PMO’s are not an optimal design for best performance. They evolved from pmo carbs, which evolved from Weber carbs. The offset/different length runners lead to slight flow variations compared to others. Shafts impede airflow more than shaftless. That being said, I like their slightly vintage look, harkening back to carbs and mfi throttle bodies. I like you can run them with the old carb/mfi air boxes. I like that they use the same factory linkage systems (easy to get parts or swap systems). I like that they are easy to adjust and don't need frequent readjustment. And while the design is not optimal, I believe it would have to be a highly tuned and refined motor build to see big differences between pmo and other throttle bodies. My built 3.8 made 372 hp (crank) on the dyno with pmo 46’s. I doubt it would have made a lot more with a more optimized design.
Gratuitous pic of the PMO’s in my ‘74.
Brooke
1969 911 ST 2.8SS EFI ITB (Irish Green), 1974 911 3.6 ITB (Black)
1952 MG TD with F20C
Old 12-14-2023, 02:50 PM
rswannabe , that's a pretty girl !!!
Old 12-14-2023, 03:07 PM
Racer
winders's Avatar
The AT Power ITBs are significantly better than the PMO stuff...they make more power using smaller diameter intakes which greatly improves low end and midrange torque.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 12-14-2023, 03:26 PM
WP0ZZZ's Avatar
As you guys say, there are probably other options that give more performance but has someone quantified it? Are we talking 5 hp or 25 hp?
@rswannabe your engine looks amazing! I agree with everything you say. The vintage look is a big plus for me and I'm ready to leave some performance on the table but before making a decision I would like to know how much performance I would be losing!
Old 12-14-2023, 07:48 PM
@nospiners - Thank you!
@wpozzz - Thanks! Unfortunately I don’t have quantifiable data for you. Nor have I seen any real back to back tests to point you towards.
Brooke
Old 12-14-2023, 10:31 PM
WP0ZZZ's Avatar
I understand that making a proper test is hard and uncommon…
I’m wondering if there are any air flow bench tests of ITBs. (Not sure if the results from such a test would be a good indicator of real-world performance though...)
Old 12-15-2023, 11:08 AM
So they finally are ready to sell them, was wondering if they would ever reappear. Suppose they will double the price like the carbs?
edit. they sure are pretty
Old 12-15-2023, 02:25 PM
I agree that some real data comparing ITB's against the standards would be great, trouble is that one will not just put in ITB's.
You are likely to upgrade to some sort of engine management system, likely tuned tighter than the stock.
You are definitely going to have to change cams to fit the changed characteristics of the engine, so that is also something that will make a big difference.
You are also likely to have a better exhaust system than stock...
....so back to back comparisons are tough.
But one data point from my past. I used to have a 240Z with the standard SU carburetors and exhaust. I replaced the SU's that were driving me crazy with triple 42DCOE Webers - no other change. The Webers were not all that well tuned, but well enough.
Well, my friend with a Ford Capri V6 which pretty well an even match with my 240Z with SU's was suddenly and definitively outclassed with the 240Z/Weber combo. In the impromptu 0-100km races we had, it used to be within a car length or so between the two cars. The Webers gave me minimum 4 car length advantage ....and going away.
Since then I have been an ITB fan...
D.
Old 12-15-2023, 06:13 PM
The 9 Store
I was told by a top engine builder that pmo itb’s are better for race engines than street. The position of the injectors and a couple details makes it harder to get a good idle and low rpm performance. Fine for the track but not as great for the street. I’m sure people make it work but it’s worth keeping it in mind.
All used parts sold as is.
Old 12-16-2023, 06:50 AM
Jeff Alton's Avatar
Have not used the AT Power ones, but they do look very well engineered. Shaftless design in very good.
We have built almost identical motors, one using Jenvey (which we used for years) and one with PMO ITB's. The difference was the PMO car was a 3.5 vs 3.4 for the Jenvey. The Jenvey engine made more power and torque everywhere despite a very slight displacement advantage. Not a true apples to apples as there are many many variables. But, a data point none the less.
The new PMO finishes look great.
The Jenvey "Heritage" ones are very unique in the look is important. Have not tried those kits yet, just their standard tapered throttles.
We have used Clewetts as well. Seemed to work ok, but the design is a bit industrial. Have a 2.7 with RHD that will be going for tuning in a couple of months as well and will report back.
Then there are the Kinsler, JSR, Borla etc.
Cheers
www.turn3autosport.com
Old 12-19-2023, 09:36 PM
Mahler9th's Avatar
Hey there... just discovering this post.
Hope all is well.
My friends at Reno Rennsport worked with AT on their Porsche applications:
https://renorennsport.com/team/
You have seen my car-- Mat Lowrance built it and has built my engines for years.
He has a lot of experience with flow work and extensive knowledge...
I suggest giving his son Brian a call.
many of my friends have experience with the AT products as a result of the work done by Reno Rennsport... one of them has a 3.6 putting out north of 400 bhp. This is a Motect-equipped engine with DBW and I was there at the dyno-- same dyno is used by a pro Formula D competitor.
My friend with the 3.6 engaged Oscar Zelaya to tune his engine-- Oscar is in pro racing and provides services tio several team, including the Action Express IMSA team that just finished #2 at Daytona.
In any case, if you want some perspective on ITBs, I suggest contacting Brian at Reno Rennsport.
Feel free to shoot me an e-mail if you want to discuss further...
Would love to catch up and hear how you have been doing!
- Mike
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 02-24-2024, 04:13 PM
lateapex911's Avatar
I just toured the PMO facility...I can't comment on their performance vs other ITBs, but I will say that their quality and construction appear to be quite nice. Just my 2 cents
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 02-24-2024, 10:52 PM
Just had this conversation with a buddy who has a 911 (CIS) and was a EFI engineer for a few companies, including Saleen and a supercar company called Kepler. He had mentioned wanting to design he own system and stressed the importance of pointing the injector directly at the intake valve, not runner, like on the PMOs.
Old 02-25-2024, 06:25 AM
JWest's Avatar
The quality has remained after the Empi purchase of PMO, but they are leaving out details and small parts. No TPS, forgotten spacers for the fuel rails, etc. Not a huge deal, but a pain if you are expecting them to be as complete as they were from PMO in the past.
I doubt most people would notice the differences mentioned here between manifold designs, but PMOs do have the vintage look that many desire.
Just finished this one with Empi PMOs. Rock solid idle and zero tuning issues.
James
JWest Engineering
Old 02-28-2024, 08:36 AM
Kind of Blue
MrBonus's Avatar
Nice, those do, in fact, look very proper and vintage.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 02-28-2024, 08:50 AM
