Hilbilly Deluxe
3.0 combustion chamber volume?
Does anyone know off the top of their head (no pun intended) the cc volume of a stock 3.0 litre head?
I am doing some Jethro Bodine Cipherin' on compression ratios, and am getting some "interesting" results. Thanks, Tom |
Re: 3.0 combustion chamber volume?
If my high school math doesn't fail me there are six cylinders to a 911 engine and if the engine is 3.0 litre that mean each cylinder should be ~ .5 litre? I don't think Jethro finish grade school he was to busy porkin Elle May, after all they were only cousins. |
Hilbilly Deluxe
That is the engine displacement, not what I am looking for.
To compute compression ratio, you need the (V1)swept volume (aka displacement), (v2) deck height volume, (V3)cylinder head volume, and (V4) piston dome volume. I just need to know what the head volume. It can be calculated I am sure, but it is usually measured by filling the head up with a liquid. Also known as CC-ing the head. the formula is: V1 + V2 + V3 - V4 --------------------- = compression ratio V2 + V3 - V4 Tom |
Irrationally exuberant
Let me guess, you're finding that the factory compression ratios are a bit higher than what you get when you actually measure them?
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Hilbilly Deluxe
Slightly lower actually, but not factory parts. Chris, do you remember what your head CC was?
Tom |
Tom,
I have a 3.2 so I don't know if it relative, but my head volume was 91.3 cu cm. They varied a bit from head to head. a 3.2 measures out to a true 9.2:1 CR I think. The factory says the compression is something like 9.5:1. -Chris
Hilbilly Deluxe
Tom |
3.0 - 6(bore X stroke)
--------------------------- = volume of cylinder head ??? 6 Is a 3.0L just the result of the stroke X bore or does it include the head volume too?
John Adams 1980 ROW 911SC |
-Chris |
Hilbilly Deluxe
Tom |
Tom,
I getcha now, it was a factory 3.2. (It's now 98mm and has a different head volume but that's another story.) -Chris
