Dipstick with no full line
I cant see the min and max line on the 75 dipstick!
Old 12-16-2021, 06:52 PM
Full Send Society
Maybe I’m seeing things, but I think I see the two marks
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 12-16-2021, 07:54 PM
Thank you.
i completely drained the oil from engine , tank front cooler and lines and addes 10 qrt.
but stick still shows no oil on stick at all ! before starting the engine.
is it safe to start the engine if tank is empty?
Old 12-17-2021, 12:53 AM
If you drained the cooler and the lines go ahead and add one more quart now than fire it up. 10 or 11 quarts is plenty to be safe for good lubrication. Just don't drive it like a track day until it is right between the two levels after it is full temp, and sits and idles for a full minutes. Check it while the engine is running.
The thermostat on the engine, and the one in the fender have to open up and circulate the oil at 180 or or more, engine idling to check the level. It is just a waste of time to try if the engine is not running or up to temp.
Old 12-17-2021, 06:12 AM
47silver's Avatar
Needs checkef at 180 degrees while running. I think that is in the owners manual
1975 911S Targa
Silver Anniversary Edition
Old 12-17-2021, 03:36 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
To emphasize: You cannot check your oil level unless the engine is running and warm. 10 quarts is undoubtedly plenty - you don't want to overfill.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 12-23-2021, 09:29 AM
Banned
Oh so sorry but i am not sure about that... Thanks !!
Old 12-24-2021, 01:17 AM
