'73 911 T Targa
Big Azz Screwdriver
I have occasional need to turn a big machine screw. I’m trying to find a slotted screwdriver with a blade wider that 1/2”. 11/16” would be ideal, but I’d settle for 5/8”.
Endless googling of “5/8 slotted screwdriver” hasn’t revealed anything over 1/2”.
Any ideas?
Old 12-29-2021, 06:55 AM
cpa cpa is online now
Would a drag link socket work?
Old 12-29-2021, 07:05 AM
Full Send Society
Get a cold chisel and grind it down with an angle grinder…. If you can weld you can add a socket to the end or leverage handles to it.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 12-29-2021, 07:07 AM
How big of a machine screw? How much leverage do you need?
Search for "coin driver" or "drag link socket". See if either of those fit your use case.
https://www.amazon.com/PB-Swiss-PB-8126-SwissGrip-Plastic/dp/B00VTLR01Q
https://www.amazon.com/Williams-SB-40-Drive-Socket-16-Inch/dp/B007YR9ZXK
You can make your own tool out of flat stock as well.
Old 12-29-2021, 07:10 AM
When I was trying to remove the big ass screw in the rear seat hinge on my 911 I finally bought a hammer screwdriver at the local tool store. It came with several wide screwdriver tips. And smacking the end of the driver helped loosen the screw. I had never before needed a hammer screwdriver.
All my big ol' screw drivers had handles that were way too long to use back there.
Old 12-29-2021, 09:11 AM
