| Registered |  Koni bump stops?
			Are bump stops required with Koni gas shocks?  I know they are not required with Bilstein.
				__________________ Steve 75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts. | ||
|  12-28-2021, 05:04 PM |
| Registered Join Date: May 2004 Location: Boulder, Colorado
			Aren't the bump stops inside the Bilstein, where you can't see them?  They are a sort of last defense against bending or otherwise damaging something when you hit a curb or dip harder than you usually do, aren't they?  With a lowered car, often cut shorter, but usually not deleted.   Though if you never hit anything too hard, maybe wouldn't matter one way or another, especially with stiff enough springs.
|  12-28-2021, 06:24 PM |
| It's a 914 ... Join Date: Jan 2008 Location: Ossining, NY
			I’ve understood that with Konis it’s best to have the bump stops. The Koni ones are better than stock rubber ones because they compress in a predictable and progressive manner. Unlike the rubber ones, which do protect the shocks, but the “spring rate” goes to essentially infinity in like 1/8” of compression.
|  12-28-2021, 08:12 PM |
