Frank,
after watching the videos it appears you assume the variation in injector duration (pin 1 uP) is root cause of your issue. Have you tried the known good DME on the simulator? Also, do both DME have the same software (chip)? This behavior might actually just be due to how your simulator drives the DME. If not it would be the A/D converter producing erratic values for load or CHT or all inputs. BTW, the spike at the end is when the injectors turn off and their magnetic field breaks down. The active snubber T403, T404, T405 absorbs most of that energy when T404 turns on. |
Ingo and others,
Thx for the feedback. I will try my good DME on the sim, but the behaviour on the car was the same, only worse since the rpm input was not stable. So I doubt it is a sim issue. And indeed, it could be that the ADC is producing unstable output. I didn’t think of that. I can only ‘see’ its inputs and as said, they are clean and stable (also both VRef’s). I cannot observe or decode the output. Given that someone has changed at least one transistor in the injector driver (I cannot see those under the cooling fin - is there a good way to get that off, seems rivetted). And some points in that circuit have been resoldered, I immediately suspected that subsystem. Now, even with 3 injectors there should be some ‘recoil’ ? Now there is nothing, less than 1 V ! If not those transistors, is the large diode maybe damaged ? (OF622) Frank Sent from my iPhone using Tapatalk |
I agree but this is puzzling me ! Sent from my iPhone using Tapatalk |
The spike at the end of the injector duration depends on what injectors you're using on the bench. In the end if the load is different the generated PWM pattern from the 0127 will be different and the amount of stored energy in the injectors is different. So unless you're having the exact same conditions on the injector output I wouldn't worry about this. I just use a big inductive load similar to injectors on my simulator so I get PWM patterns and reactive end spikes. |
Nice setup if you have a tester-dme like that. Indeed that helps.
To be clear : the large spike on my good car is 6 injectors AND the good dme. The ‘no spike’ is observed with 3 identical injectors (I’ll try 6 tomorrow) to my good car and the bad DME. Same was observed (no photo) on the car with 6 injectors. I put a copy of my 1985 original eprom in the bad dme to make sure it is the same as there was an unknow chip in there. I’ll have to read up on how this ADC works / is controlled by the cpu (OE, ALE ?) and check all the paths to the cpu. Same for the latch and eprom paths. Sent from my iPhone using Tapatalk |
If you have access to a 2-channel o-scope you can verify the output of 0127 on pin 5 to see how the snubber turns on at the end of the injector cycle. Even with a 1-channel you should be able to check that signal from pin 5 through T405 and R413 and verify that T404 turns on.
Good luck, and have fun! |
I am not changing any parts yet as you & Ingo pointed out there could be other reasons for the disturbance.
I will first compare again to my good dme on the sim (same conditions). Then figure out a way to ‘see’ if the adc is generating a good output to the cpu. I assumed the digital board was indestructible ;-) I will also hook up the full six injectors ( first check if my bench power supply can take that load). When it eventually comes to it, no prob on redoing some components in the injector driver. I can order most of those for around 20 eur all together. Even the adc is only a 6,5 eur part. But as you stated, I’d better do some deeper analysis first. Sent from my iPhone using Tapatalk |
Frank, you seen my answer to your PM last night? (Thank you again for the schematics.)
As I told you, I think the missing 50V pulse is intentional in the know good DME. Check this page with typical waveforms. Though different technologies, they show that the closing "high voltage" pulse is there to accelerate the closing of injectors. In the schematics, it appears that this function is provided by the ZY47 (D401) zener diode. This is a 47V diode. May be this diode should be checked? |
OK,
so with the hints from yesterday, work continued. :o I should have checked everything again when attaching the chain of injectors yesterday ! I was having a bad case of noise in my AFM feedback from the simulator to the Motronic. That was probably causing the jumping effect. I seem not to be able to get rid of the noise, so I wired up my spare AFM and it is much more stable, on the 'good' and the 'bad' Motronic box. http://forums.pelicanparts.com/uploa...1641566150.JPG http://forums.pelicanparts.com/uploa...1641566150.JPG Only significant difference is (same conditions, same inputs, same injectors) : - good box : at closing a large positive peak is seen (as can be expected) - bad box : no positive peak @Ingo : I got my old analog scope back from the attic, here is a trace of pin 1 (drive of the main darlinton) vs pin 5 ('snubber') output of the Bosch 0127 IC. It seems that the snubber circuit is turned on much at the same time than the main transistor or am I reading this wrong ? https://youtu.be/uYn7Jre2OiI More investigation to do, Frank |
Sorry, wrong pic posted for the 'bad' ECU, this is the one with the same conditions.
http://forums.pelicanparts.com/uploa...1641567003.JPG |
Frank,
I noticed the funny pattern in the hold section of the injector duration in your “bad” DME. This doesn’t look right. It’s almost as if the current feedback is oscillating. Look at your good DME where this pattern isn’t present. I have seen marginal 0127 before. They do work but have sustained some kind of degradation or damage. That’d be my guess. https://uploads.tapatalk-cdn.com/202...980e7058cf.jpg I wasn’t able to see much on your analog scope video but if I have time I’ll record and post some scope traces later today. |
I have checked T406 : seems to be working, it opens during the whole cycle. - bottom channel = T402 injection signal - top = Collector - emitter voltage T406 http://forums.pelicanparts.com/uploa...1641571111.JPG Then after R413 i get this and don't understand how this is supposed to work : - bottom = same T402 main injection - top = base T403 (PNP) http://forums.pelicanparts.com/uploa...1641571323.JPG More or less the same signal then at the T404 http://forums.pelicanparts.com/uploa...1641571414.JPG Frank |
@Ingo : the bottom irregularities are due to the timebase on the el-cheapo scope (35 EUR). On the analog scope they line up quite nicely at the bottom.
As I didn't understand the previous waveforms, there had to be something wrong in the snubber circuit and I believe I found it finally. The diode over the T404 transistor appeared not to be doing it's job. So I desoldered it and (a) it was the wrong type in there (possibly due to my schematics being of a later version that this board) and (b) passing current happily in both directions ?! Replaced by one that I had (1N4007 instead of a 1N4002) and I can now see a correct waveform. http://forums.pelicanparts.com/uploa...1641579482.JPG The board is happily running now with 6 injectors. Heat after 30 min of running is 44°C or 113F on the heatsink, so well under control. http://forums.pelicanparts.com/uploa...1641579565.JPG Too late to put it into the car and test it, that will be for tomorrow. |
Ingo |
Spcial thanks to Ingo for all the help and asking the right questions. I runs super smooth in the car now ! It seems even better/smoother than my 'good ECU'. And incidentally, once this was fixed, the heavy noise in the power supply and ADC of the arduino in the simulator are gone. it did add some caps to better control it though. But 2 projects finished at once : the bad ECU repaired and a good simulator for the future. And I learned a new area of my Porsche that I didn't really know before. Thanks again, Frank |
| All times are GMT -8. The time now is 02:56 PM. |
