Motronic 3.2 debugging idle
Hi,
Question for the Motronic ECU crowd ! I have a 1985 Motronic on the test bench (std chip) that allegedly has a 'rough idle' & 'shakes to a stall' problem. I will only be able to test it in the car next week. Apparently the car is driving around 'no problem' with another Motronic DME. Doing the checks, the DME seems to respond to all inputs in a normal way (speed signal, reference signal, CHT, IAT, ...). At 800 rpm, it holds a very stable pulse towards the coil at the required frequency and a nice injection pulse. However, when I vary the rpms a bit (speed signal), there is almost no reaction to be seen on the ICV output. The duty cycles slowly changes a bit (max 10%). I can get an 'immediate' response if I change the CHT input from cold to warm for instance so the driver circuit works. So is the assumption correct that the ICV is not used to regulate idle ? Or should it react promptly to changes is rpm (700 - 900 variations) ? I would appreciate any pointers on how the idle regulation circuitry actually works on these Motronics. Kind regards, Frank |
https://uploads.tapatalk-cdn.com/202...56e3c43894.jpg
Photo of my Motronic ECU tester for attention ;-) Can anybody explain how the idle gets regulated by the motronic ? (1985 std chip) Frank Sent from my iPhone using Tapatalk |
The ICV is used to regulate idle, that's its job. The ECU feeds a pulse-width-modulated signal to the ICV to control the idle speed. You might need to adjust the AFM gate spring position in the airbox thingy. By the way, it might be more informative to measure the Air Fuel ratio using an AFR meter.
I can see that the ICV is a block wave signal. I was expecting it to vary quickly when I deviate from the idle rpm (800) to compensate. However, I can only see very small/slow changes in the duty cycle (idle switch connected to GND).
I was wondering if I can check anything in the dme itself ? Sent from my iPhone using Tapatalk |
Make sure your closed throttle contact switch is making contact. It’s the two wire connector.
If the idle contact is open for any reason, the ECU will not control the ICV because it thinks the throttle is open. |
The ecu is off the car and I simulate the switch by putting pin 2 to ground. It does react immediately to the idle switch on / off but only seems to regulate the ICV on very large devitions of the rpm.
I traced the signal back on the board to the processor and this is indeed how the processor outputs the signal (in the 5v domain). It seems to act as a slow PID controller, I was expecting a fast-following controller ? I can vary the output more by simulating a cold cyl head temp than it reacts to the rpm changes (600 -1100 rpm) Frank Sent from my iPhone using Tapatalk |
When I do this on my DME simulator I look for are a couple of things. First, with the idle switch engaged and WOT not engaged verify that fuel pulses cut out above something like 3000 RPM. This verifies the idle switch is logically correctly recognized by the DME software. Idle and WOT switch inputs are internally wired into a resistor network to one of the 8 A/D converter inputs. Theoretically, if the A/D converter has an issue or the resistor network is wrong the DME might misinterpret your input on pin 2 as another condition.
Next, if you watch an ICV while setting the simulator to around 880 RPM and AFM input near lowest reading you will see that the ICV reacts fairly quickly to slight variations of the RPM thereafter. However, this only happens in a small band around the setpoint RPM. Once you increase RPM it closes and when you exceed a certain RPM the ICV snaps back to a different more open position. I assume that is so it can "catch" RPM dips when you close the throttle body by letting of the accelerator. And as you correctly identified the output is a differential PWM signal with about 100 Hz. So in other words one output is the inverse of the other. That signal is also used as watchdog input. With this heartbeat absent the MCU resets. Ingo |
Ingo,
many thanks for the pointers ! I repeated some tests : 1. The IDLE switch is recognised and works as described by you. Under 'idle' the injectors cut out at about 1600-1700 rpmFlip the idle swicth off and it goes to a 'standard' duty cycle immediatly (exact value depends on CHT) I don't quite understand your final comment : "That signal is also used as watchdog input. With this heartbeat absent the MCU resets."The only input to the ICV circuitry that is rather isolated is the ADV11 output from the uP ? Kind reagards and thanks for sharing these insights already ! Frank |
UPDATE : I see what you mean, the Motronic checks the presence of the ICV output signal internally through IC S890 and resets the CPU if required.
If not, it was continually reset until "up & running". Most all processors now days have a internal watch dog timer which does that function. |
Thanks,
Learning so much here. The icv signal is present, I monitored the reset circuitry and it is not resetting the cpu as far as I can tell (unless the reset are very short pulses). I do see an immediate (moderate) reaction in the duty cycle and as Ingo said, once idle gets high it goes to a fixed position to anticipate throttle closure. So far so good. What I do notice is that the pulses towards the injectors are ‘reset’ once every 2 seconds to an extremely long injection pulse (as if afm is full open/wot) and then they decrease step by step until it hits a certain length again and it ‘resets’. Also clearly audible in the injectors. So if it is providing a varying injection pulse with stable inputs, that would probably be the cause of the ‘unstable idle’ and it is partly masked at higher rpm? I am going to see the car now and test all the sensors ‘live’. Pretty sure it will be rough with this unstable behaviour, I will post a video of this behaviour afterwards. Also noticed someone has been ‘in here’ before as one of the transistors in the injection circuit is non-std. Frank Sent from my iPhone using Tapatalk |
Following this very interesting thread, trying to learn and understand how the IDE works. However I only have the schematics for the 944/951 version of the Motronic IDE. Would anybody here have a decent readable jpg or pdf copy of the 911 version that they would be willing to share via MP? |
Send me a PM for the schematics No problem finding most of the original transistors here. Sent from my iPhone using Tapatalk |
PM sent. Thanks.
Silicon Labs IDE "The Silicon Labs Integrated Development Environment (IDE) is a complete, stand-alone software program that includes a project manager, source editor, source-level debugger and other utilities. The IDE interfaces to third party development toolchains to provide system designers with a complete embedded software development environment." Quote:
So if you have a good copy of the 911 version and are willing to share it, please don't hesitate. :) |
You can always buy a 944 DME ECU on eBay versus relying on a marginally accurate schematic. They're cheap! |
OK, back to the original problem ;-)
First we ran the car with another (known good) DME - no issues, clean idle, good injector waveforms, nice acceleration. With the problem DME, idle was indeed rough but the ICV was regulating as Ingo said in a relatively small band around 800 rpm. However, the idle quickly got 'out of control' sweeping to 2000 rpm, dropping to 500 rpm and always eventually stalling. (Way too wide for the ICV to control anything) Checked and known working : Idle switch, ICV, stable Vcc on the board (both 13.7 Vbat and 5.05V on the 5V level), O2 disconnected, Vref stable on the ADC, all inputs stable on the ADC, ref & speed pulses stable and correct on the uP. When looking at the injection pulse (pin 1 uP) and the resulting 'peak & hold' output with the whole injector chain connected (I couldn't replicate that at home) the problem became clear : the injection pulse jumps up and then shortens, then jumps up again. With 3 injectors connected now I can replicate the problem on the bench . Video of injector pulse (pin 14) here : https://youtu.be/bQrVtaFdOKA Video of output on pin 1 of the uP here : https://youtu.be/g_ePbtH7nv4 The uP pulse comes through correctly on the R421, although through ADV12 on this board (older board than the schematic). However T405 has been replaced by a 2N3019. http://forums.pelicanparts.com/uploa...1641488531.JPG Another thing I noticed, even with 3 injectors running, I do not see the positive peak on the scope at closing (first pic below) as I do on my good running car (last pic below). http://forums.pelicanparts.com/uploa...1641488849.JPG http://forums.pelicanparts.com/uploa...1641488849.JPG Any help in this area is greatly appreciated ! Probably gonna check my stash of electronics and see if I can find a BC639C to make it closer to the original again. Kind regards and thanks for helping me along this quest... Frank |
| All times are GMT -8. The time now is 01:11 PM. |
