Swapping seats: help ID what's underneath
I am tied of my power seats not work properly so I'm swapping with a pair of manual ones I recently got from a fellow pelican. I was finally able to remove the passenger seat (PITA). Can you help ID what I found underneath (see photo below)?
Note: Car is a 1976 with a transplanted 3.2 and G50. #1 - active Motronic ECU? #2 - DME? #3 - I have no clue #4 - Old ECU? #5 - I have no clue I am thinking of removing #3, 4, and 5 because they don't look to be wired. Last edited by hunter92040; 12-30-2021 at 03:53 PM.. |
Hmmm...I've never had a challenge posting photos before. This one is 500 KB PNG format. |
#1 - active Motronic ECU? - Yes
#2 - DME? - DME Relay #3 - I have no clue - Aneroid barometer; for changing the fuel map above 3000' #4 - Old ECU? - Yes #5 - I have no clue - Something just kicking around.... |
my 87' with its stock 3.2L/G50 has only 1,2, and 3 - 3 being the altitude sensor.
Sent from my iPhone using Tapatalk |
Is it possible that ECU 1 is a modified ECU and ECU 4 is a stock one so you can pass emissions?
Harry D makes a good point.
If your car is a ‘76 it would not have had a Motronics DME by Bosch, those were introduced in 1984. Looks like #1 & #4 have the same numbers on top, it would be interesting to see if both work. You could remove 4 and send it out to be bench tested.
************************* Socbum '88 911 Coupe |
7.0:1 > 11.3:1 > 7.0:1
#5 looks similar to a 964 turbo ignition module, called EZ69. It may well be from some random car but look and see if the part number has 965 prefix.
