Front tire wear issues
I've been experiencing excessive front inner tire wear with my 73 911. I don't track the car, just normal driving and occasional "spirited" mountain drives...
At the present time I'm running 1/16" toe in, 0 camber and all the +caster I can get. Front tire wear is unacceptable, rears wear rather well. I accurately do my own alignments with my alignment bubble tool and toe plates.
The car has Pirelli P6000 tires, turbo tie rod kit. The car has not been lowered. 26F 29R PSI
My inclination is to try for 1* +camber but something tells me I'm not seeing the whole picture.
Thoughts? Ideas? Thanks!
1973.5 911T ——-1974 914/1.8
Old 01-30-2022, 08:26 PM
If the tire wear is on the inside of both, toe it IN a bit more. Camber off won't wear out tires anywhere near as the toe being off.
Old 01-31-2022, 01:45 PM
HarryD's Avatar
Tire pressures are too low. 29 F/34 R is factory.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-31-2022, 03:22 PM
HarryD's Avatar
You have two identical threads going. Delete one please.
My tech spec bbok says:
total toe (pressed with 15 kp) = 0
camber 0 +-10
Harry
2020 MB E350 4Matic
Old 01-31-2022, 03:30 PM
Several things can cause your problem we need more information like Control arm bushings and condition, ball joints, suspension set up et. Highly unlikely it’s just tire pressure.
Old 02-01-2022, 08:47 AM
HarryD's Avatar
Possibly true, but why not start with the simple, easy to do things first.
Other inexpensive things to do are a close inspection to verify the condition of the front-end components (ball joints, wheel bearings, bushes etc). Make sure nothing is bent!
Harry
2020 MB E350 4Matic
Old 02-01-2022, 11:17 AM
Brew Master
cabmandone's Avatar
I was looking into this issue on my car and came across a few threads that stated negative camber was the problem.
Inner tread wear on front tires only
Harry is correct. First thing is to verify everything is mechanically sound. That means raising the car and checking wheel bearings, tie rod ends and ball joints. Once that is inspected then you should move onto alignment. Most reputable alignment shops will do the inspection prior to aligning the vehicle but if you're capable, it'll save you a few trips to the alignment shop.
Oddly, my rear tires seem to wear the center prematurely
Nick
Old 02-02-2022, 04:26 AM
Of the tire wearing angles, incorrect toe is BY FAR the one that will shred tires the quickest.
Agree with a thorough front end inspection, although with an early 911, you can feel "something loose" fairly easily when driving because they normally feel very precise when driving.
How about a pic of the two front tires?
Old 02-02-2022, 04:44 AM
Why didn’t I think of that?????????????? WTF
Old 02-02-2022, 05:49 AM
prschmn's Avatar
A picture of the wear would be helpful-wear from toe vs camber is easily identified.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 02-02-2022, 07:22 AM
midnight911's Avatar
I'd also check toes first.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 02-02-2022, 07:53 PM
