brittbolen's Avatar
Where does the fuel vapor line attach to the air filter on a 69 MFI car
There are 2 fuel vapor lines in the engine bay one connects to the engine shroud, the other should connect to the air filter assembly. I can’t figure out on a 1969 air cleaner where the vapor/evap line should attach. The 70/71 cleaners have a tee on the back one for vapor and one for oil tank breather, but my 70 seems to have a 69 air cleaner and it only has a fitting for the oil tank.
Plan b is to find a tee with 2 1 inch sides and 1 1/2 side and hook that up…
B
Old 01-05-2022, 01:25 PM
brittbolen's Avatar
Back of my air cleaner with just the fitting for the oil tank and the little drain line, but no where to attach the evap/vapor line
Old 01-05-2022, 01:27 PM
'69 cars did not have fuel vapor recovery systems , so no place for the hose on a '69 air filter housing .
Old 01-05-2022, 08:37 PM
brittbolen's Avatar
We’ll that explains that… wonder how I ended up with a 69 air cleaner in my 70…
Old 01-05-2022, 11:16 PM
HarryD's Avatar
You could go with a Euro vapor system like what is shown in post 14 of this thread: https://forums.pelicanparts.com/porsche-911-technical-forum/299053-tank-ventilation-mfi-diagrams.html
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-05-2022, 11:36 PM
Eng-o-neer
Tremelune's Avatar
Fire, carb change, "hat" style filters, and confusion...They changed the box from metal to plastic and back once or twice at random points of time between '69-71...They all have slightly different nozzles and shapes and they can all sort of kind of be used together with some monkeying...
My guess is someone changed it to hats and then someone else changed it back to stock...but missed by a hair.
Old 01-06-2022, 08:48 AM
brittbolen's Avatar
Perhaps. I’ve got records to 85, so that’s 15 years of mystery! Another mystery… I have a mix of plastic and metal throttle Venturi under the cleaner…
Old 01-06-2022, 03:53 PM
brittbolen's Avatar
See 2 plastic and 1 metal. Same on the other bank.
Old 01-06-2022, 03:55 PM
