Where does the fuel vapor line attach to the air filter on a 69 MFI car
There are 2 fuel vapor lines in the engine bay one connects to the engine shroud, the other should connect to the air filter assembly. I can’t figure out on a 1969 air cleaner where the vapor/evap line should attach. The 70/71 cleaners have a tee on the back one for vapor and one for oil tank breather, but my 70 seems to have a 69 air cleaner and it only has a fitting for the oil tank.
Plan b is to find a tee with 2 1 inch sides and 1 1/2 side and hook that up… Thanks B |
![]() Back of my air cleaner with just the fitting for the oil tank and the little drain line, but no where to attach the evap/vapor line |
'69 cars did not have fuel vapor recovery systems , so no place for the hose on a '69 air filter housing .
We’ll that explains that… wonder how I ended up with a 69 air cleaner in my 70…
You could go with a Euro vapor system like what is shown in post 14 of this thread: https://forums.pelicanparts.com/porsche-911-technical-forum/299053-tank-ventilation-mfi-diagrams.html
Eng-o-neer
My guess is someone changed it to hats and then someone else changed it back to stock...but missed by a hair. |
Perhaps. I’ve got records to 85, so that’s 15 years of mystery! Another mystery… I have a mix of plastic and metal throttle Venturi under the cleaner…
![]() See 2 plastic and 1 metal. Same on the other bank. |
