fuel accumulator
last year prior to revamping the oil cooling system (rad and fan in front fender) I experienced difficult "hot" starts a couple of times..hasnt occured since but havnt experienced high engine temps since the redo. I suspect the fuel accumulator may have been a culprit..is there a simple way to test it?
thanks bob 77 with 83 sc engine |
Testing your fuel accumulator..........
Bob, Remove the fuel accumulator from the car and bench test it. These are how I test them on the bench:
There are a few more tricks but try the above first to test and evaluate your fuel accumulator. Keep us posted. Tony |
Tony
could you explain the vacuum test method for me, i have a vacuum test tool but unsure of setup because there are 3 ports |
Another method without removal is putting a gauge on the system
and without the car running crack the bleeder for a sec and see if the pressure comes back after releasing it. Also pull the bottom line-no fuel should come out of the accumulator-if it does the diaphragm is bad.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
being a neophyte re testing with a vacuum gauge, i need to know which port (bottom, top left, top right) to place the gauge on and what to do with the other 2 ports during the test
sorry to be such a dunce |
Nope.........
There will be some residual fuel coming out from the bottom port when you disconnect it. This is not a good test to evaluate a three-port FA. Once a fuel accumulator is used in a CIS, the bottom chamber would have raw fuel. If you don’t believe it, try it yourself. Tony |
Yeah, They all bleed sufficient fuel out the bottom fitting to get a shop rag dripping wet. A popular improvement is to use the larger, later model accumulator.
Fuel accumulator leak test......
You could test your 3-port or 2-port fuel accumulators for leak several ways: a). Using a hand vacuum pump: ![]() b). Using positive air pressure: You could use air compressors, foot pump, or simply blow it using your mouth. I used my breathe to create bubbles in the water. ![]() ![]() ![]() The bubbles below may not look obvious in the picture, but in actual test the bubbles were very obvious for the presence of leak source. ![]() I’m 79 years old and weighs less than 137 lbs. soaked and wet, so most of you surely would have no problem using this method. Tony Last edited by boyt911sc; 01-14-2022 at 08:55 PM.. |
Thanks Tony....will attempt this weekend if not too cold in the garage
