-   -   Spark Plug Socket Size for 77 2.7L 911S (http://forums.pelicanparts.com/porsche-911-technical-forum/1110345-spark-plug-socket-size-77-2-7l-911s.html)
tonyduc 01-10-2022 10:14 AM
When I purchased my car it didn't come with a toolset, I therefore need to know the socket size of the spark plugs so I can by an aftermarket tool such as the Gearwrench swivel tool popular with many on this forum - it comes in 2 sizes: 5/8" and 13/16". The Pelican article says 13mm (which is about 1/2"), did they mean 13/16 ? I'm likely looking for equivalent for the Bosch w235p21 referred to in the owner's manual.
Tony
Locker537 01-10-2022 11:12 AM
Yes, they meant 13/16.
The Gearwrench 13/16 magnetic socket is the one I prefer.
imaircooled 01-10-2022 12:30 PM
Magnetic being the key word here. Those plugs are way down in there so being magnetic will help out a lot.
Chris
tonyduc 01-10-2022 01:13 PM
Thanks to both !
Showdown 01-10-2022 01:57 PM
Magnetic for sure, and also get a little grabber claw or a magnet on a flexible arm for when the the plug falls down and you start *****ting bricks.
HarryD 01-10-2022 04:41 PM
You will need an extension to a standard spark plug socket to get to the plug. I use a 3" one that I gorilla tape to the socket so it does not separate inside the valve cover.
kimlangley7 01-10-2022 05:00 PM
Personally - I've found after 35 years of Porsche 911 SC ownership [1980 911 SC - the best spark plug tool is the one in the 911 toolkit... just works the best for me..
HarryD 01-10-2022 05:17 PM
Indeed but the OP does not have a factory tool kit with this tool.
