Spark Plug Socket Size for 77 2.7L 911S
When I purchased my car it didn't come with a toolset, I therefore need to know the socket size of the spark plugs so I can by an aftermarket tool such as the Gearwrench swivel tool popular with many on this forum - it comes in 2 sizes: 5/8" and 13/16". The Pelican article says 13mm (which is about 1/2"), did they mean 13/16 ? I'm likely looking for equivalent for the Bosch w235p21 referred to in the owner's manual.
Thanks Tony |
Yes, they meant 13/16.
The Gearwrench 13/16 magnetic socket is the one I prefer. |
Chris
Chris 1974 Porsche 911 Targa w/935 flat fan twin turbo motor, not really "DTW" Dave W. "There is really not any such thing as a rebuild 'on the cheap' on a 2.7 motor. You'll either pay now, or you'll pay later, but you'll pay." |
Thanks to both !
Full Send Society
Magnetic for sure, and also get a little grabber claw or a magnet on a flexible arm for when the the plug falls down and you start *****ting bricks.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
You will need an extension to a standard spark plug socket to get to the plug. I use a 3" one that I gorilla tape to the socket so it does not separate inside the valve cover.
Personally - I've found after 35 years of Porsche 911 SC ownership [1980 911 SC - the best spark plug tool is the one in the 911 toolkit... just works the best for me..
Kim Langley 2012 Carrera / 991.1 80 911SC 97 C230 73 BMW 2002Tii |
Indeed but the OP does not have a factory tool kit with this tool.
