-   -   Modified 3.2 ignition question (http://forums.pelicanparts.com/porsche-911-technical-forum/111113-modified-3-2-ignition-question.html)
Hatari 05-18-2003 07:28 AM
The 3.2 I posted a thread on a while back is in completion stages. The short list is:
9.8:1 JE pistons
Headwork by Memphis Motorwerks
Jerry Woods GE-60's, springs, retainers
46mm PMO's
Rods resized and balanced
Raceware rod bolts
Complete rebuilding inside case, new head studs
I finally elected to not go the twin-plug route thus the lower compression ratio, for a several reasons. I have a locked distributor from a 930 (and yes, we changed the drive gear on the crank to coincide). The engine should be completed and ready to start up in a couple more weeks.
I'm down to planning the ignition system...I'm thinking about an MSD 6AL box, but will need a timing computer to control the advance (hence locked distributor). MSD's website lists a couple of products that should do the job, but I'd appreciate any feedback from those that may have gone this route already.
Wayne, I see that you have the 6AL, can you get the MSD computers also?
Some progress photos are at my site:
http://brentwoodrocketscience.com/r2/r2.htm
Thanks,
Jack McAllister
CamB 05-18-2003 02:09 PM
Cool!
Search for the user name "A Quiet Boom" and "timing" - Christian put some sort of MSD product with a customisable timing curve onto his 3.0 with Zeniths. He was very happy with it.
http://forums.pelicanparts.com/porsche-911-technical-forum/76843-few-3-0-questions.html?highlight=timing
I have no idea which MSD product he is actually refering to!
Hatari 05-18-2003 02:12 PM
Cam,
Thanks, I'll look it up.
Jack
