Fuel pressure questions
On quest to sort my carbs
I've fitted a pressure regulator. I have no return line which is the issue I think.
On running I can set to 3psi. With the car off and IGN on it just keeps building up. I have seen 6 PSI. Also I'm guessing at a high speed it will drop below the 3 PSI.
Car seems to run fine as is. I haven't beat on yet but I'm sure it be fine.as it's not a race car.
I have viton needles on order. This is all to sort a flooding problem I had on cold s start up.
Of interest if I let it pump and get high PSI on a start up it will put black spots on my garage floor. So it's definitely getting excess fuel leaking into my engine.
My practice is now 4 pumps. IGN on and crank asap. Seems to work fine.
Am I all good with this pressure regulator or ??
Thanks lyndon
Old 01-20-2022, 05:24 PM
No, not good. You need to flow the excess pressure back to the tank.
What model car and what fuel pump?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 01-20-2022, 05:57 PM
That's not much work. I have no provision in my tank or lines running thru the car
Lyndon
Old 01-20-2022, 05:59 PM
Hey Lyndon
Shane is right , you need to have a regulated return.
PMO sells the one I choose to use , but you can make on by putting a Tee in the pressure line run the free line to the regulator and carbs and the other side of the Tee back to the tank .
The trick is to put a small plug in the return line with a 1.5 mm hole in it , this allows the pressure to bleed off to the tank,
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 01-20-2022, 06:19 PM
Ok it's a 68 911
My Pump is a pierburg efp085pie.000
3 to 5 psi.100lph.
Lyndon
Old 01-20-2022, 06:30 PM
I remember Lyndon,
If you don't have a return line to the tank you can install a 60 degree y pointing back to the fuel pump suction side , with the regulated return line .
ian
Old 01-20-2022, 06:47 PM
As per my diagram. I can do all this in the engine bay with a few tees and make a restrictor.
Lyndon
Old 01-20-2022, 08:40 PM
Lyndon , yes those are the basics .
Old 01-21-2022, 08:40 PM
I've put a bridge in. Also a 8mm bolt X 10mm. Drilled to 1/8th. Then Solderd and drilled to 1.5 mm. Put halfway in the bridge.
I can adjust to 3psi perfectly. No build up on engine shut down and nil variation on revs in neutral.
A road test tomorrow to confirm.
Thanks lyndon
Old 01-25-2022, 02:48 AM
Eng-o-neer
Tremelune's Avatar
Why, ah...why all the plumbing? My car has Webers and a single line and low-pressure fuel pump in the front...
With regard to the return loop (neat trick), how did you figure out 1.5mm restriction? I'm thinking of going EFI, and I'm not sure what to do about a return line...
Old 01-26-2022, 07:48 PM
My car has one line from the tank . The pump is in the engine bay. That's front the factory.
After 52 years I guess all the pumps are a little high that you buy now. After about 18 mths off trying to this correct I think I've got it. It's starts idles and runs better than ever. I should have fitted the pressure regulator long ago.
Lyndon
Old 01-26-2022, 09:30 PM
Another member suggested 1.5 mm
Old 01-26-2022, 09:31 PM
