-   -   Where does this attach? (http://forums.pelicanparts.com/porsche-911-technical-forum/111159-where-does-attach.html)
IROC 05-18-2003 03:23 PM
I'm getting down to the wire in swapping a 3.2 into my '76, but was going over the connections to the engine, etc., and found something that I don't know where it is supposed to attach.
http://forums.pelicanparts.com/uploads/P518xx.JPG
In the photo, I am trying to figure out where the vacuum thingie that attaches to the airbox actually attaches to the engine. I originally attached it to a 10mm engine tin screw right below the airbox, but this doesn't seem right as I don't think the engine will do into the bay with it right there.
Can anyone help me out?
Thanks!
Mike
marcesq 05-18-2003 03:42 PM
If it's this vacuum thingy . . . pull it off and plug the hole in the airbox
http://forums.pelicanparts.com/uploads/P5182x.jpg
marcesq 05-18-2003 03:53 PM
Remove and plug this one toohttp://forums.pelicanparts.com/uploads/P5184x.jpg
IROC 05-18-2003 04:05 PM
Thanks!!! It was that vacuum thingie. BTW, I've been using your website pretty extensively throughout this swap and just wanted to tell you that it has helped a bunch. I'm putting an '88 3.2 into a '76 and most of the stuff has been the same.
marcesq 05-18-2003 05:39 PM
Mike:
Hope it helped more than hurt. Great feeling when it fires up for the first time, and the feeling just keeps on coming every time you hit 4000.
Good luck.
IROC 05-18-2003 05:48 PM
Marc,
One more question (a stupid one, I'm sure). The DME wiring harness - when it comes into the engine compartment - has a large bundle of brown wires that I am assuming are a bunch of ground wires. Here's the stupid part - does this attach to the engine somewhere (the PO of my engine tagged this bundle "engine"), or does it simply attach to a ground lug on the chassis in the engine compartment?
Thanks alot!!
Mike
jazzbass 05-18-2003 06:25 PM
There is a large bundle of brown wires that attach to the intake manifold on the left side of the engine - going to the #1 cylinder, IIRC.
marcesq 05-18-2003 06:29 PM
Mike:
The ground harness that you are talking about has more than 3 brown wires . . . . yes.
If so there is a bolt (if it's in the right hole) between the number 1 and 3 intake runners facing the coil. That is where this ground harness is bolted. I think the bolt has a 10mm head.
marcesq 05-18-2003 06:30 PM
Chris types faster than me, we are talking about the same thing.
IROC 05-19-2003 05:10 AM
Thanks, I really appreciate the help. Alot of this stuff isn't intuitive when you're standing there with a handful of DME harness and an empty engine bay.
Mike
