l_turn9's Avatar
Green Oil Warning Light in Dash
Hello All!
The Oil Temp/Press Gauge in my 74 911 has 3 warning lights. The top one is Green and stopped working a while back. I removeed the gauge and removed the bulb and wiring holder the bulb was pushed in to. The bulb is good - I tested it and it is the proper # and type. I also used a 12V Test Light to check the bulb socket and when the key is on I see power. But I am either not properly pushing the bulb into the holder correctly or something else is going on. Now I've been putting bulbs into their various sockets since I started working on Porsches in the late 60's and rarely did it wrong.
Has anyone else seen a problem like this? Any suggestions?
Thanks -
Larry
Old 02-25-2022, 11:38 AM
Uncertifiable!!!
Uwon's Avatar
What year?
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 02-26-2022, 04:02 AM
l_turn9's Avatar
sorry about that - it's a 1974 911 base model.
TIA
Old 03-02-2022, 10:41 AM
ROW '78 911 Targa
timmy2's Avatar
Wire color going to it?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-02-2022, 10:47 AM
l_turn9's Avatar
Every time I pull almost any gauge, I am amazed at the wiring designed into it! The
oil gauge light has 4 plugs with the following wires piggybacked :
1 Brown / yellow
1 Brown / yellow
1 brown / Blue
1 Black / Blue stripe with green rings.
TIA -
Old 03-02-2022, 12:22 PM
ROW '78 911 Targa
timmy2's Avatar
Brake warning lamp K-7
From….
F-6 Brake warning switch on MC.
F-9 Hand Brake on
Hazard flasher
Brake light sensor J34 terminal A
Ideally it is off, and only comes on when there is a problem.
Set the hand brake with ignition on to check.
Dennis
Old 03-02-2022, 02:41 PM
