charles
MFI stuck rack
Tracking down source of fouled plugs I pulled MFI pump (2.4S engine) and injectors for cleaning.
After opening the pump up it was loaded with sludge. I soaked pump in berryman's B12 chem-dip for 2 days, rinsed that out with carb cleaner. I was fortunate and was loaned a heated ultrasonic bath - back into berryman's for several rounds of cleaning Cleaned it all out again w/ carb cleaner then methanol. Filled it with oil and let that sit overnight. Pulley turns over fine, but rack is stuck. I put wood dowel in rear hole and w/ mild pressure am unable to get rack to move. I can rotate the gears above pistons by hand and get rack to move but it does not return. Suggestions welcomed |
Pacific fuel injection or Mark Jung for a rebuild
sounds like a foreign object is jamming the rack
Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
It's a 914 ...
Have you opened the pump? Pulling a side cover isn't a big deal to do. Might reveal something.
Coram Deo
I would suggest that now that the rack is free you put it back through the ultrasound.
Also, the throttle return spring will close the pump; I don't know that pumps are spring-loaded to close on their own (but my experience is from a relative) Mercedes MFI pump question
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Hbrand
Mfi
I got mine to work using GUM Out.
Removing the 6 top parts and working the pistons down with a dowel. Greetings
Cheers 1982 Porsche 911SC Euro 1969 Mercedes 280SL 1956 Austin Healey 3x |
charles
Thanks for replies.
I have pump in diesel in ultrasonic cleaner again. I can now push on back of rack w/ dowel and get it to move, so progress, but still no return. re spring: perhaps return spring is weak - i'll see if I can source replacement. re: remove check valves & push pistons down - can you expand on this? I pulled one of the check valves off just to see if it looked clean inside, and it appeared OK. What did you do, spray gumout onto pistons? thanks charles |
It's a 914 ...
Sounds like progress!
Sometimes a good penetrant like PB Blaster can do things oil can't, might be worth a try. Another thing that wouldn't be evident from external testing - make sure the pistons/plungers aren't stuck. You can have stuck plungers and the pump will still spin (but it wouldn't work in that condition). Plungers are visible with the side cover off. Plungers are another place that some penetrant can help if stuck. |
