Proper pliers for washer tube clamps?
I am in need of a pair of pliers for the tube clamps that go on the windshield washer lines on a 1988 911 (930). Took a trip down to Home Depot, Napa auto parts, and a local smaller hardware store without luck. The closest thing I could find was 1/4" irrigation tube clamp pliers at Home Depot but they were way too large.
Any idea of where I might be able to get the right sided pliers? Here is the clamp part: https://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=999-512-527-00-OEM |
Search Oetiker clamp tool. I doubt you'll find it at Home Depot but maybe some auto parts stores might have it. Abundantly available online.
Walt 82SC 3.0 81SC 3.6 Last edited by walt; 02-19-2022 at 05:28 PM.. |
thanks!
I needed a tool to crimp the band on my CV Joints. I found this at Lowes that worked perfectly:
https://www.lowes.com/pd/Apollo-1-2-in-to-1-in-Poly-Pinch-Clamp-Tool/3723138
Racer
I am a fan of this tool:
https://www.amazon.com/Lisle-30800-Boot-Clamp-Pliers/dp/B0002SREPY/ref=sr_1_60?crid=1Y5Y4YTD1J1EY&keywords=oetiker+clamp+tool&qid=1645347225&sprefix=oetiker+clamp+tool%2Caps%2C164&sr=8-60
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
just get yourself mini horseshoe pliers...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
49willard
I used my sons Oetiker crimp tool yesterday on the fuel return line refresh. He was an Audi tech for 20 years so he has the tool. In the process of doing my engine drop refresh I am also redoing my half shafts and will use it for those clamps for the new boots. The tool is setup to work either straight on or to the side at 90 degrees for getting into tight spots. Given its construction I suspect it was not cheap when he bought it years ago.
Bill 1961 356B coupe-long gone! 1986 Grand Prix White Cabriolet |
