Third Brake Light
Hello,
My third (rear window) brake light isn't working on my '87 Targa. When I popped it off to replace the bulb, the gasket disintegrated. I replaced the bulb and put the light back without the gasket. It still didn't work. Questions:
1) Can I get a replacement gasket, or do I need to replace the entire third brake light?
2) If I need to replace it, is this the right part?
https://www.pelicanparts.com/More_Info/91163108000OEM.htm?pn=911-631-080-00-OEM&bt=Y&fs=0&SVSVSI=815
3) Pending replacement of the entire light, or the gasket, any ideas on how to get the light to work? (I need to pass a safety check.)
Thanks!
Scott
Old 02-21-2022, 10:49 AM
proporsche's Avatar
did you try it with the ignition on?No need to buy the light just get yourself 2way tape...
Check your ground to it with test light..are your other brake lights in working order?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-21-2022, 12:23 PM
Thanks. Other brake lights are working. I only tested with the power on, but not the engine. I’ll test as you suggest.
Old 02-21-2022, 12:37 PM
Schulisco's Avatar
I'm not pretty sure, but I might remember that I read somewhere that the factory third brake lights is connected on one of the two brake lights in the tail lights. Please check out in the wiring diagrams for your car. It could be a contact problem or even a broken cable.
Check also with a multimeter the voltage is delivered to the socket, probably it's a contact problem within the socket.
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 02-21-2022, 02:18 PM
Tags
1987 911 , third brake light
