El_Mecanico's Avatar
What are these little turds?
For several years I have found little cylindrical carbonized poop like substance...Its not from any animal. Its hard like carbon. Most concentration is the air intake filter. However it makes its way around and some settle under the oil pressure sending unit. The only thing I do know is the the KN filter was not inserted properly. It was facing back wards. Could this had been produce from inside the engine? Has any one seen this before?
1986 Porsche Carrera
1997 Porsche Boxster (Sold) :0
1995 911 Cabriolet (Sold)
1971 Porsche Targa 911E (Sold)
Old 09-24-2011, 12:16 PM
Here some more pics.
Old 09-24-2011, 12:20 PM
GaryR's Avatar
Send a message via ICQ to GaryR
They are the pellets from the carbon canister in the engine compartment, must have broken open or cracked.
Gary R.
Old 09-24-2011, 12:21 PM
Southern Class & Sass
Dixie's Avatar
They're pellets from the charcol canister.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 09-24-2011, 12:27 PM
THANKS...would that affect performance or make the car smoke at idle? Where is the canister?
Old 09-24-2011, 12:53 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Should be just above/forward of the oil tank. Black plastic cylinder.
Who Will Live... Will See
Old 09-24-2011, 01:09 PM
steely's Avatar
The canister is to the right of the Airbox - in the engine bay - on the inside of the fender.
You may want to remove the Air filter and inspect inside the air box, since when these go, they can be vacuumed into your intake.
There's at least one other thread on here.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 09-24-2011, 01:11 PM
I think everyone else is wrong - those are definately chocolate sprinkles.
Old 09-24-2011, 01:27 PM
It must have been removed or blown up cause I can not find it...I removed the air filter...nothing. Is is next to the oil tank? Some one have a pic? I looked in my Porsche manual and it doesn't show it.
Old 09-24-2011, 01:28 PM
JJ 911SC's Avatar
The black cylinder by the fire wall at the top left of the pics
Old 09-24-2011, 01:30 PM
WOW I don't have one of those...since I bought the car...three years ago. Does an 1986 have one there to?
Old 09-24-2011, 01:39 PM
Ok where did they come from?
Old 09-24-2011, 02:11 PM
Tidybuoy that's exactly what they look like. I wonder if I trashed the engine. I'm in the process of found a top end.
Old 09-24-2011, 02:16 PM
KNS KNS is offline
Check up inside the right side upper rear wheel well, sometimes they are located there (if that is not a charcoal canister then what is it?).
Kurt
Old 09-24-2011, 02:39 PM
Here is my car right side engine compartment. Notice that there isnt even a hose for the canister.
Old 09-24-2011, 02:46 PM
Different shot after removing air filter assembly.
Old 09-24-2011, 02:49 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
its mounted under the right rear fender, not in the engine compartment. look above your oil thermostat.
Old 09-24-2011, 03:28 PM
Rattlesnake...there she is right where you said. I dont see a hole in the hose going to the airbox. Since my air filter was not installed correctly thats the most likely reason why the pellets were following out from underneath the air filter covering and lying around in that area. Now how much damage did the engine receive from pellets and dirty air? I was planning on doing a top end due to smoke and oil consumption. I had great compression although I haven't retested for a couple of years. Do you think those little pellets just destroyed my engine?
Old 09-24-2011, 03:58 PM
JJ 911SC's Avatar
While mine is in the engine bay (83 body), I end up putting mesh screen on all 3 ports that has line connected to them.
I got steel "sink aerator" from Lowe's, fold them over the port and slide the hose over.
1$ a piece. Do not use nylon one.
Old 09-24-2011, 04:14 PM
RETIRED
Joe Bob's Avatar
Carbon Fiber Mice....
2012 ML350 3.0 Turbo Diesel
Old 09-24-2011, 04:23 PM
