cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
Help with oil leak
89 Carrera 3.2
It never leaked a drop. Replaced the clutch and main seal and it started leaking. Replaced the main seal again with a genuine Porsche seal. Its still leaking. Looks like its leaking down the side of the cooler where it meets the engine. What might be the cause?
When I had the engine out. I did not notice excess oil in the triangle of death area.
Many Thanks,
Chris
89 Carrera
3.2
Old 02-27-2022, 01:27 PM
HarryD's Avatar
Usual suspects: Triangle of death, failed cooler seal, failed cooler.
My story: https://forums.pelicanparts.com/porsche-911-technical-forum/1095055-failed-oil-cooler.html
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-27-2022, 02:04 PM
proporsche's Avatar
well? you did see the oil there and you did not inspect? or did you...2x ? picture of the oil leak would help
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-27-2022, 02:08 PM
Remove the air flow meter assembly so you can see the TOD area.
206 637 4071
Old 02-27-2022, 03:21 PM
cmcfaul's Avatar
I think its coming from the upper cooler seals. Maybe it just needs a tightening (doubt it). Taking it to the shop today to get a professionals opinion. I thought it was the main seal as I had replaced it when replacing the clutch and the leak started so replaced it again, huge pain in the ass. I am getting burned out on fixing it. Pretty sure its not the main seal.
Chris
Old 02-28-2022, 06:12 AM
proporsche's Avatar
as John said look on the top if there is a oil leak you`ll see it also take picture so we can see it the top and where the oil comes down..
ivan
Old 02-28-2022, 08:45 AM
I was able to remove the oil cooler without dropping the engine.
Per Ivan, be aware of this tech bulletin if you end up removing the oil cooler.
https://forums.pelicanparts.com/porsche-911-technical-forum/1011282-leak-cooler-seals.html#post10227300
Old 02-28-2022, 10:01 AM
cmcfaul's Avatar
The top of the engine is wet. Believe its the oil sender. Gonna replace that and hope for the best.
Thanks,
Chris
Old 02-28-2022, 10:47 AM
Do some JB weld around the plastic at the crimp with the new one, they leak there after awhile.
Old 02-28-2022, 05:39 PM
Walt Fricke's Avatar
Even the JB weld reinforcement isn't forever.
I fabricated a plug for the idiot light sender when my reinforced one started leaking, and bought a VDO two pole sender unit I have mounted at the rear (of the car) of the engine where the oil pressure sender goes. This unit combines a pressure sensor for the gauge, and an on/off switch for the idiot light. Hasn't leaked yet, plus if it does it is easy to get at. Just calls for a short wire extension for the idiot part.
Old 03-01-2022, 05:53 PM
