My tire Advan A052 rub has been located
On the heels of this thread:
Tire choices suck. 1985 911. Yokohama Advan A052? After bushing replacements, alignments, corner balancing, and the works trying to sort these Yokohama Advan A052 tires and the horrible rubbing, I have finally located my tire rub from the left side. The culprit? This AC line bracket: ![]() Discovered yesterday during the first 911 Autocross since 2011. I noticed this bracket was off at a 45 degree angle. I moved it to where it's seen now, and took a few circles. Sure enough, it was off at 45 degrees again. Tried to bend it in further with a block of wood and a hammer. No go. So I rotated it upwards fully out of the way. Still a slight bit of rub on that hose though. The bracket was chewing the tread off the edge of the tire! ![]() I'm hoping there's enough slack in the sag there to move the hose up further out of the way, nearer the top hose. I assume it's routed like it's supposed to be, but it seems kinda dumb to have it hang so low like that. Pics of yours? I do not want to remove the AC. And for fun, here's my best and wort run of a rainy day.
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
Maybe remove the lower clamp and zip tie the hoses together.
What is that smaller line between them, John? Now I have a desire to clean up in there... ![]()
Do you mind sharing your front suspension and wheel setup?
What is your ride height set at?
1987 M491 Widebody, Nautic Blue / Linen with a 1979 930 3.3L Cali Engine |
Wheels: 6" front, 7" rears. Authentic Fuchs 16" I'm pretty sure John Walker installed Bilstein shocks back in 2008. More info in the previous thread. Current Alignment: ![]()
