Got Boost?
IMONBOOST's Avatar
Need Fuel Injection info: SC vs. Carrera 3.2
Ok, I will be converting my Carrera 3.0 (Similar to SC) to a Carrera 3.2 intake Electronic Fuel Injection controlled by a MegaSquirt. I know there are people on this board using the MegaSquirt but my questions do not concern MS for now. I would like to know the following information:
1. Pressure rating for Carrera 3.0 (SC) Fuel Pump?
2. Pressure rating for Carrera 3.2 Fuel Pump?
3. What is the fuel pressure on a Carrera 3.2 Fuel Injection System?
The reason I ask is once I mount the 3.2 intake with it's injectors fuel rails, fuel pressure regulator, will the fuel pressure change using the Carrera 3.0 Pump?
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work."
-Ayrton Senna-
Old 05-20-2003, 12:34 PM
