1973 Tach and Speedometer w SC engine?
I plan to replace the existing 2.2L engine and 901 transmission in my 1973 911T with a 3L Sc engine and a 915 transmission. Will my tach and speedometer work or do I need later versions? Thanks
Old 03-01-2022, 07:04 AM
what version of 915, cable or electronic speedo?
tach may need TachAdapt, no bit deal.
Old 03-01-2022, 07:35 AM
915 has electronic connection, no cable. I believe it is a 1979 911Sc 915
Old 03-01-2022, 07:47 AM
A 73T should have a 2.4 engine and 915 transmission??
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 03-01-2022, 07:48 AM
You will need to get a later electronic speedo. Any of them 76-89 will work
If your tach is a 73 tach it should work fine.
Old 03-01-2022, 07:49 AM
Ok thank you. It is possible to modify my 1973 speedo?
Old 03-01-2022, 07:58 AM
No. The early ones have a mechanical drive and the later are electronic. No way to modify.
Old 03-01-2022, 08:00 AM
my car had the original engine and transmission swapped out at some point. So, free from a numbers matching car, I have a 1979 Sc 915 transmission and plan to build a 3L Sc engine for the car. I plan to sell the 2.2 engine and 901 transmission cheap.
Old 03-01-2022, 08:01 AM
I was afraid of that.
You can look for a 72-76 915 which will have a mechanical drive or swap the speedometer. It's only 2 wires through the tunnel for the electronic speedo, but the needle on the later speedos won't match your other silver button needles.
Old 03-01-2022, 08:04 AM
Ok I will replace the speedo with a later 76-89 electronic version and have it painted too match my other gauges. Thank you for your help. Much appreciated.
Old 03-01-2022, 08:07 AM
Dakota Digital makes an electronic to mechanical speedo drive. So you could use your stock speedo. It is just a box that takes your electric feed and drives a little motor that drives your speedo. Easy to find at places like jegs and summit. Like $350
Old 03-01-2022, 10:14 AM
Great thank you. I'll check that out
Old 03-01-2022, 10:16 AM
Have you used that box in a 911? I was looking at it a few months back but couldn't find anyone that has used one.
Sent from my SM-G991U using Tapatalk
Old 03-01-2022, 11:35 AM
no I have not used one in a Porsche. this is my first Porsche I am planning on using this box. I have used these speedo conversion boxes on past muscle car projects that I have done. they worked well no complaints
Old 03-01-2022, 01:07 PM
