Question Oxygen Sensor light on??
On the way to drop off the SC for some much needed A/C work, the oxygen sensor light came on. I checked the manual, which states that the sensor light functions as sort of a maintenance reminder, however, my mech thinks the sensor maybe blown or that the connecting wire was ripped out somehow. I'm suppose to hear from him sometime today. By the way, the previous owner just replaced the sensor last year. What do ya think?
Is it easy to install a new sensor, I'm already expecting a nice bill for the A/C, really don't want to hand over another arm or leg for installing a sensor. Thanks.
Old 05-20-2003, 06:46 AM
Mine came on about 3 months ago, the week before I had to have an emission check done. I panicked but then checked this board and saw that it was more than likely just a reset. I did the reset, per the manual, and sailed through emissions. They may not have reset it when they swapped the sensor. I think it runs on 30k cycles but not positive. Good luck.
Old 05-20-2003, 07:08 AM
Newbie mistake, I posted before I did a search on the board. What do ya know, I found a thread telling exactly how to reset the sensor. However, I am still interested in knowing how to replace it if need be. From the threads I read, it didn't sound too hard.
Old 05-20-2003, 07:13 AM
UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
It's as simple as replacing a spark plug; I did it a couple of months ago. Just be sure to soak it with liquid wrench the day before you want to take it off.
Matt
'82 911SC Targa!
Old 05-20-2003, 07:46 AM
Senior Member
Superman's Avatar
Changing a spark plug is substantially more complicated than changing the O2 sensor. At least you can SEE the O2 sensor.
If it was replaced recently, then it does not need replacing now. Be very skeptical if they try to sell you an O2 sensor. If the car passes emissions, then reset the O2 light and drive. IN fact, I believe the mileage counter (the thing behind the speedo that has the reset button) is grounded by a brown wire than runs to the tach. At least that is my faint recollection. Unplug this ground wire, tape it up (for safety) and you'll never have to reset the O2 light again. It comes on every 30k miles. The O2 light circuit has no way of knowing whether your O2 sensor is working or not. It just comes on every 30k miles. There is no correlation between the light and the sensor itself. None.
Mocha 1978 911SC. "Coco"
Old 05-20-2003, 08:48 AM
Thanks for the help. Hopefully I will be able to return the favor someday.
Old 05-20-2003, 02:48 PM
