Locked lug nuts
Just pulled a 1989 Porsche 911 sunroof coupe out of a barn and it has one locked lug nut on each wheel. No key available.
Any suggestions how to remove the lochs?
Old 03-15-2022, 02:25 PM
No suggestion, but that sounds like a great barn find!
Old 03-15-2022, 05:43 PM
Red Line Service
Marc Bixen's Avatar
Slide hammer. All 4 in 1-2 minutes! Early "Key" style are easy.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 03-15-2022, 06:03 PM
Porsche dealer has keys for original wheel locks. It's in a case, probably around 24 different ones. They took mine off from my 1987.
Old 03-15-2022, 06:23 PM
Bill Douglas's Avatar
No key available
So it's not in the glove box, the tool kit or hidden in the smugglers box (steering shaft access)?
Old 03-15-2022, 06:27 PM
Chisel bit in an air hammer gets most of them. Sometimes a big socket hammered on tight. Sometimes the top breaks off and leaves the bottom, then a 3/4" deep hole saw finishes the job. Several different types out there.
206 637 4071
Old 03-15-2022, 10:18 PM
Brew Master
cabmandone's Avatar
I tried to post a link but it was crazy long. They make universal tools to remove locking lug nuts. Harbor freight sells a kit or you can find them on Amazon.
Nick
Old 03-16-2022, 04:14 AM
^^^^ This ^^^^
The universal tool is used with a 1/2" drive impact wrench. Spin it fast enough to break through the chrome or beauty finish, then it bites in. Then carefully hit it further on with a hammer and drift, then spin it off with the impact wrench. Sometimes they'll even come off at the "breaking through" stage.
Old 03-16-2022, 04:37 AM
if you know a machine shop, they can take an impression of the pattern with modelling clay and then cut you a socket. That's how I got mine off back in the day of a lost key.
Lost 2.7l engine #6141641, drop me a line if you find it.
Old 03-16-2022, 05:59 AM
Senior Member
Superman's Avatar
I think this would be kinda fun, in a twisted sort of way. I think I would cut a notch in a corner/side of the nut and use an air hammer with a chisel bit to rotate the nut counterclockwise. I'd be surprised if this didn't work like a charm.
Mocha 1978 911SC. "Coco"
Old 03-16-2022, 07:28 AM
The air hammer trick might work, but if you slip, it'll leave a big nasty mark in the wheel. How much do you trust your aim and steady hand with the air hammer?
Old 03-16-2022, 09:22 AM
Never nicked a wheel. You use it gingerly, not full blast.
206 637 4071
Old 03-16-2022, 10:14 AM
Senior Member
Superman's Avatar
It was John himself who introduced me to the magic of removing fasteners with an air hammer. Works great on stuff like ball joint nuts you will not re-use. Saves wear and tear on the special tool used for tightening.
Old 03-16-2022, 10:29 AM
I never implied that one of us pros here would nick a wheel, but someone who has never done it before certainly could.
Old 03-16-2022, 12:46 PM
I've used a 12 point 1/2" socket that's slightly smaller than the locking lugnut OD... Use a decent sized hammer or small sledge to hit the socket onto the locking lugnut and use a 1/2" breaker bar to turn CCW. Use a long bolt or punch to drive the lock out of the socket.
Old 03-16-2022, 03:56 PM
Brew Master
cabmandone's Avatar
Hey! Watch how you use that
Nick
Old 03-16-2022, 05:18 PM
If it is a factory lock, then it would be a cover that needs to be removed to access the lug. The self biting socket and air hammer will not work for that style. The slide hammer is quick and effective.
If a locking lug that requires a dedicated socket, go for the air hammer or self biting socket and impact.
Old 03-17-2022, 10:46 AM
On the factory locks with the spinning cover, use an air hammer bit sideways at the upper notch and knock the top off. Easiest one of all to get off. All 4 in 2 minutes.
206 637 4071
Old 03-17-2022, 11:18 AM
