What’s this?
I’m replacing the flywheel seal and rear pulley seal on my 71 911 2.2. I came across this below the rear pulley (circled in yellow). Is it common to replace the gasket at this time?
Mark
1971 911E targa
Priors:
1955 Speedster, 74 911 coupe, 69 911T coupe, 74 911 slant nose w/928 lights, 03 911 Turbo
Old 03-16-2022, 07:20 PM
Discseven's Avatar
Intermediate shaft cover. If it's not leaking, my choice would be to leave it alone.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 03-17-2022, 06:59 AM
I think it may be leaking. It it a simple job to change the gasket?
Mark
1971 911E targa
Priors:
Old 03-17-2022, 07:24 AM
No better time than now.
Old 03-17-2022, 08:49 AM
Discseven's Avatar
Remove those 3 nuts. Gasket is a couple of dollars. Clean the mating surface area of the case and cover plate well---without gouging or scratching those surfaces. The plate's mating surface can be put on a glass window to ensure it's nicely flat. Good idea to get 3 new nylock nuts. Not sure if the washers there are bowed. If they are, I'd do new on those---cup of bow faces towards the case. Check both sides of the gasket before installing. Shouldn't be any deformities on either side and should be clean---no hairs, etc. Torque those nuts to spec working around each nut a little at a time---to compress the gasket progressively. Is a subtle step but as I see it, is worth treating gaskets with some finesse. With parts in hand, is maybe half hour project.
Karl ~~~
Old 03-17-2022, 10:29 AM
Karl, Thank you so much for taking the time to explain that
Mark
1971 911E targa
Priors:
Old 03-17-2022, 12:00 PM
