How to tell if a spring plate is the desired adjustable ones?
Are there numbers identifying the ones that have more adjustablilty?
You can tell just by looking. An adjustable spring plate is a two piece plate. Looks like this:
http://www.pelicanparts.com/catalog/...ring_plate.JPG A non adjustable will be one solid metal plate all the way back. |
Chris is showing an aftermarket Sway-a-way adjustable spring plate. More specifically, it's a G50 Sway-a-way.
The factory adjustable plates look like this: http://forums.pelicanparts.com/uploa...onebearing.jpg Note the two large bolts near the pivot. Those are the adjusters. Non adjustables lack those bolts. |
Oh, oops... Chuck, Did the factory ever make a plate that wasn't adjustable that way?
I'm partial to the factory adjustables. They provide adequate range, probably 1.5 inches total.
The sway-a-ways are heavy and the design is clunky. To each his own. Chris, yes the factory plates before '76 (I think) lacked those adjusters. |
| All times are GMT -8. The time now is 05:39 AM. |
