Flojo's Avatar
RPM counter doesn't work (after engine swap - need help
Hi,
I need your brains please.
So I recently did an engine swap to my 79 SC
- old 930.06 out
- new 930.20 in
Motronic and wire harness was fully working fine in donor car.
My car runs as well.
But not the rpm counter :-(
Acording to wire diagram the signal comes from pin 21 of Motronic and goes to pin 2 on rpm counter (black/violett wire).
I thoroughly traced that wire and confirm it comes from pin 21 and reaches all the way into the frunk. Made a firm extension from there to rear of cockpit.
I have 3 rpm counters (yes, working, tested):
- a late 78 from my SC
- a Carrera one stamped 87
- a Carrera one stamped 88
My connection with both Carrera rpm counter:
- mass to pin 6 (existing brown wires)
- ingnition plus on pin 5 (existing red/black wire)
- signal/TD to pin 2 (black/violet wire)
My connection with SC rpm counter:
- mass to pin 1 (existing brown wires)
- ingnition plus on pin 3 (existing red/black wire)
No reaction from any of the three counters... where is my "problem"?
Thank you
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-22-2022, 01:55 AM
Ginger77's Avatar
Your Instagram shows a working tachometer. What was the culprit in the end?
Diederick
I drive a US import 1977 911. Formerly owned by a woman in California named Ginger - which appropriately led to the nickname.
IG: no dedicated account but photos are posted with #ginger77
Old 03-23-2022, 06:09 AM
Flojo's Avatar
Yes. Works now.
Wiering was unlogic. PO did something hidden to my understanding.
Never trust wiering you didn’t do yourself, haha
Old 03-23-2022, 06:44 AM
