915 gearbox fill plug
Hi.
I am looking for a fill plug for my 1982 915 gearbox that I can modify to mount a temp sensor in. I am looking for one that looks like the one in the picture. Anyone that knows if this one will fit my gearbox? The one in the last picture is the one my gearbox has at the moment. Cheers ![]() ![]() ![]() Sent from my iPhone using Tapatalk Last edited by Classic 911; 05-24-2021 at 05:29 PM.. Reason: Wrong spelling in title |
Take into account that the Fill Plug will be above the oil level - It might not be the most desirable location for a temperature sensor
915 grarbox fill plug
Thanks very for your your input Yes I know the sensor absolutely should be placed in a better and lower location on the gearbox housing than in the fill plug to be submerged totally in the oil and thus give accurate reading. The reason for choosing the fill plug is that it’s the quick and easy way to get some sort of temperature readings. Given it will mean that the sensor only will get oil splashing combined with the internal air mixture I will have to ad "some" degrees to the readings to get an idea of the "life inside" the housing. But if someone has a equally quick and better way and idea of where to mount a sensor without dismantling the gearbox I would really appreciate the input ![]() Cheers Sent from my iPhone using Tapatalk Last edited by Classic 911; 05-24-2021 at 03:51 PM.. |
This is what we use - but we also have a cooler and CMS race built 915 (very expensive) . . .
https://californiamotorsports.net/products/cms-915-fork-cover-plate Regards, Roy T Quote:
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
Be careful using any plug in the fill hole that protrudes into the gearbox. Having the magnet knocked off and land in the bottom of the case is a somewhat common occurrence. It's caused, I believe by the OEM steel plug being over-tightened into the aluminum case and cutting the pipe thread deeper into the aluminum. The factory only put the magnetic plug in the drain, not the fill. Many feel you catch twice as much "fuzz" if you retrofit the magnetic plug in both. I think that not to be the case.
I think a temperature sending probe might get battered by the internal gears. If you insert one, make sure you have clearance inside the box (like with a lump of clay) when it's tightened down. |
I think the thread pattern is likely the same.
I agree, not the best place to get temps. There is at least one thread somewhere in these Forums about transmission oil temps to which WEVO contributed-- might be worth a look. WEVO have a product that one could use for a temp sensor: https://www.wevo.com/Products/TransmissionProducts/WevoTransmissionProducts-Cooling_XT095OilOutletBottomCover.htm WEVO are local to me and I have known them for over 20 years. My application has been club racing. During this time I have used a 915 transmission driven by at times a 3.8 and currently a 3.6. Horsepower from around 330 to 360 or so. Longest races have been ~35 minutes, and highest ambient temps have been 100-105. I strongly considered installing a pump and cooler set up, but decided it wasn't worth the bother. Several friends installed them back in the day, only to discover that the temps never really got high enough for much, if any benefit. What has been far more important for me is diligence in general transmission maintenance, in replacement of worn parts, and in use (shifting).
Mike PCA Golden Gate Region Porsche Racing Club #4 BMWCCA NASA Last edited by Mahler9th; 05-25-2021 at 08:46 AM.. |
Thank you for the input Yes I have taken those things into consideration ![]() Sent from my iPhone using Tapatalk |
Thank you Roy ![]() Yes I have been looking at that solution but I find it too expensive ![]() Sent from my iPhone using Tapatalk |
Thank you for the tip Yes I have been looking at that cover plate but I find it too expensive for what I am after. ![]() Sent from my iPhone using Tapatalk |
Just reading through this thread. I wonder if this is a possibility?
https://www.lindseyracing.com/LR/Parts/911ODP.html |
My fill plug is still pristine looking after cleaning it, and it certainly has caught a lot of crud in the many miles I have driven it. Just my one car sample pool of data. I will continue to run a magnet core drain plug in my fill plug.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I'll be less equivocal than other posters: putting the temp sensor in the fill plug will not give you useful information. The old-style 19 mm external hex plug is probably easier to machine a sensor into than the new style 17 mm internal hex plug, and you'll be able to remove the plug without first removing the sensor from it. As an alternative to these tapered plugs, you could use a straight thread plug with a seal ring (crush washer) https://belmetric.com/steel-hex-drive-metric-drain-plug-din-910/?
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
