Not Stig's Avatar
Sudden shimmy shake
I took my 87Targa out for a drive after sitting due to the pandemic lockdown. I drove on the freeway for about an hour and the car ran perfectly, nice and smooth. On the way home I was entering the freeway onramp, a sweeping right hander at about 35 MPH when the steering wheel began to vibrate and shimmy. I thought it must be the road surface and continued onto the freeway. On the freeway the vibration and shimmy continued so I thought I must have a tire going flat. I pulled off and checked the tires and they were fine. I did not hit any potholes or curbs during the drive. On the drive home I noticed that he shimmy shake stopped when turning to the left and then started again when going straight or turning to the right. When I got home I checked the following.
Tire Pressure, OK
Wheel weights, all in place
Lug nut torque, OK
Tire damage, None, no blisters, good tread, 10 years old, 9000 miles
Wheel bearings, very slight amount of play on right front
Help! What should I be checking next!
Old 10-31-2020, 09:36 AM
Rodney Nelson's Avatar
I would check those tires again. This happened to me on a set of 10 year old tires with about the same amount of wear, or maybe even less, they looked brand new. I was on the freeway and then all of a sudden the shake started happening. I thought it was the road too. Then when I slowed down it was not there anymore.
Then a week later I was on the freeway again and I noticed it. Then it started to get worse and worse. I pulled over and could not find anything wrong with the tires or suspension. I was in the middle of nowhere and had to call AAA. While it was getting loaded on the flat bed the driver said here is the problem. It was one of my tires, in the middle a blister. Of course I was parked right on it when I was doing my inspection.
Pulled the car back off installed the spare and ordered a new set of tires. What they say is true. 10 year old tires need to be replaced even if they look brand new.
I would mar your tires and inspect, roll a bit, inspect, roll...
of course a shimmy at a certain speed can also be a wheel balance issue.
I would replace all of the tires have everything balanced and see if the shimmy goes away.
my .02
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold
Old 10-31-2020, 01:15 PM
Sounds like a belt shift on one of the treads . New tires will fix that
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 11-01-2020, 03:08 AM
Targa_PB_78_SC
mike sampsel's Avatar
Probably not your issue, but my shimmy which was pronounced at straight driving turned out to be a weak ball joint. Around 97 K miles I replaced mine, and no more shimmy!
BareRearedRookie
Old 11-01-2020, 03:18 AM
10 year old tyres on my car started to delaminate giving rise to vibration that was hard to spot until I had a really good look at the rear tyres. So suspect tyres delaminating.
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 11-01-2020, 03:37 AM
Driver, not Mechanic
10 year old tires... I'd replace them.
Old 11-01-2020, 08:14 AM
Reiver
Reiver's Avatar
You need new tires anyway so go that route of elimination...... prob the issue
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-01-2020, 09:06 AM
Flojo's Avatar
dear God! a street sport tire hardens at about 5-6 years.
get new ones asap!
a minimal play is OK. but the feel shoulb be in spec 1:1 for left and right.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 11-02-2020, 06:35 AM
Not Stig's Avatar
Thanks for the great advise, based on age the tires should have been replaced year ago. I will replace the tires and report back.
Old 11-02-2020, 08:11 AM
creaturecat's Avatar
should be some tire obvious damage, if it happened in a matter of seconds. no?
a balancer would indicate problems if it's tire-related shake and shimmy. no?
you check control arm bushings, etc?
Old 11-02-2020, 08:33 AM
shoooo32's Avatar
I'm guessing a loose wheel bearing. It doesn't take much to give you a shimmy.
But yeah, get some fresh skins asap. 10 year old tires are toast no matter how much tread.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 11-02-2020, 10:30 AM
Not Stig's Avatar
Bump for Shimmy shake update and mystery
First let me stipulate that I know I need to replace the tires due to age. Now for the mystery. When I checked the wheel bearings, I noticed a small amount of play on the right front wheel. I grabbed the tire at the twelve and six o'clock position and was able to rock the wheel slightly. I decided to check the wheel bearing adjustment, so I removed the wheel and the dust cap and tried to move the thrust washer with the tip of a screwdriver. It took quite a bit of effort to move the thrust washer so I assumed the bearing adjustment was OK and the play must be somewhere in the suspension. I reinstalled the wheel and tried rocking the wheel to see if could see movement in the suspension. The play was completely gone. WTF! No, the wheel was not loose. I had checked the lug nuts with a torque wrench before and after I removed the wheel. I decided to go for a drive to see if the shimmy continued and thought to myself it's wishful thinking that the shimmy was somehow cured by taking the wheel off and putting it back on. Guess what? The shimmy shake was completely gone. Since then, I've driven the car for hours on all kinds of roads at different speeds and no shimmy shake. Can anyone solve the mystery for me?
Old 03-23-2022, 09:33 AM
Perhaps ensure your upper steering column bearing has not disintegrated?
Old 03-23-2022, 10:04 AM
Senior Member
Superman's Avatar
I wonder if a worn ball joint could do this, or a worn tie rod end.
Mocha 1978 911SC. "Coco"
Old 03-23-2022, 11:40 AM
Lash
If you do not have access to a lift take it to a good tire alignment shop and have them inspect for worn ball joints, bushings etc.
Lash
1963 356 T-6 Normal Coupe
1972 911 T Coupe ..... Sold
1972 911 S Targa ...... Sold
1980 911 SC Coupe Weissach
Old 03-23-2022, 02:16 PM
Brew Master
cabmandone's Avatar
You didn't happen to do brakes on the front and pump the brakes before you had torqued the wheel did you? I don't recall how the 911 rotor is held on the hub but I've seen guys get the rotor out of whack by not installing the wheel and at least tightening it before pumping the brakes.
Pretty much a yes to both. And both can have the same feel as a worn wheel bearing. You need to have someone watching as you wiggle the tire to make sure it's the wheel bearing or a ball joint/tie rod end issue. I made the mistake of changing a wheel bearing only to find I needed to replace a ball joint once.
Nick
Old 03-24-2022, 05:15 AM
This! 10 year old tires are not a good idea. Think about it, the ONLY contact the car has to the ground is the little patch of rubber of the tires. Old tires can look perfect, but have lots of problems. I bet one (likely a front) has a delamination or bubble in the rubber. Take the wheels off, and inspect both front tires. You might find the issue. Order new tires anyway.
And drive your 911 more! I never have old tires as I wear them out before the get old. I have 182,000 miles on my 911.
Old 03-24-2022, 09:43 AM
