LED Turn Signal Behavior
Hi everyone
I know there are a bunch of threads out there about this. I have read them all and none cover the issues I am having with my LED turn signal lights from CarMagic so I am hoping someone here might be able to help. I have installed Rennline LED headlights with integrated turn signals and a full set of Engleberts LEDs (CarMargic) Before I go further Englebert has been extremely generous with his time although was not able to offer any solution as yet. All LEDs work fine apart from his front turn signals. Symptoms are:
I got a little fed-up and ordered my own LEDs from Amazon knowing I can return them if they don't work. As soon as I swapped the CarMagic LEDs for the Amazon LEDs I solved the running light problem. The running lights now work as they should in all settings. However, I now have a new problem:
This affects both driver and passenger sides equally. Here is a video which shows what I mean: <iframe width="560" height="315" src="https://www.youtube.com/embed/bQvtIDF30HI" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe> Does anyone know what could be causing this? Do I need a resistor somewhere for the turn signal lights? Could it be a bad ground? If so how do I test for this? I have a multimeter but not sure how to use it to know if I have a bad ground on the turn signal lights. If I find a bad ground how do I fix this? If SPOKESWORKS is out there I am using the CarMagic EP26 relay. I believe yours is different by grounding the C2 pin? Would this fix my issue or is that solely related to the instrument LEDs which on my car are now working fine with the Amazon LED bulbs. Thanks so much everyone!! |
I haven't worked my way through all this yet but thought I'd ask, Do headlights on VS running lights on have any effect?
Thanks for looking at this!!! No - there is no difference between running lights on and headlights on. Symptoms remain the same in both states with the exception that headlights are on.
the leds draw less..do you have a correct relay?
I'm assuming the LED turn indicator have 2 wires separate from the headlight wiring?
are you tying the ground into the existing harness going to the turn/gunning lights in the bumper? my first thought is that you accidentally connected the the LED turn between the turn signal supply and the side marker supply lines. I would try running the led turn light ground directly to the chassis so that only the LED Turn supply is connected to the original harness. this may help you isolate the problem. |
Yes, I'm referring to the LED turn indicators in the headlight assembly. Those are the ones I'm inquiring about the ground wire connection on. I would suggest running the ground from the headlight turn signals as dedicated grounds. I have the Rennline headlights but without the integrated turn signals. how many wires do the Rennline with turn signal, have and does the turn (orange) also double as a running (white) light when the running lights are on but headlights off?
The integrated turn signal lights in the Rennline lights are an LED halo module that add to their light housing. And yes they double as running lights (white) and turn orange and flash as turn signals when turning L/R. From that LED module there are 3 wires:
Perhaps I am wrong but as this all works perfectly well with a stock bulb in the front indicator(s) I am tempted not to mess with this wiring. I am wondering if I need to add resistors to the turn signal wiring? Would this mean that the LED bulbs would then appear to carry the same load as a stock bulb and therefore solve the issue I am having? |
do you have LEDs in all the rest of the locations F/R turn and marker? how about instrument cluster?
Dual filament or single filament bulb that you are installing in the turn signal location?
yes, just making sure you have the correct style bulb going in with the 2 contacts on the base as a single contact on the base would short the running light to the turn signal supply, which would cause the issues you are seeing. it may be remedial but can you check to make sure the contacts on the base of the LED aren't shorting between the 2 terminals in the housing?
Yes - 2 contacts on the LEDs, exact same positioning when compared to stock filament bulb and definitely no shorting going on. Terminals are clean, Ground contacts all seem clean and the fact that both left and right turn signals are affected identically leads me to think that it is likely not a housing or contact issue.
when you change from the factory incandescent bulb in the fron turn signal does it change the behavior of the rear lighting?
No. Rear lighting functions perfectly both with stock filament bulbs and when changed to 1157 LED
Don't add the ballast resistors as you would just be masking some type of wiring issue. The turnsignal circuit and running light circuit are separate except in one place: The turnsignal/running light bases which should be ground. If the ground is not there one filament may get powered through the other filament. With the OEM bulb in place, can you tell if just the high power filament flashing or do both filaments flash? |
| All times are GMT -8. The time now is 05:56 AM. |
