Analog Air Cooled
Confirming that a Late model SC ALTN is compatible with 3.2?
I think my new Valeo ATLN / internal VR is bad. I can’t shake this over voltage problem. Randomly still fluctuation with Revs and then the fun starts. Not as high as it was but 15.V is not where I want to be. Lights really get it going..
I want to use a buddies SC ALTN with internal VR as a final test. Batt is good Replaced , isolated or serviced every Motor in the car. Grounds are checked. Yet the Voltage wil just go off. Fried my blower resistor in the process. Nothing I can think of will cause over voltage except a Bad cell, ALTN, VR, or a motor..
86 Targa 91 964 13 6 SPD Cayenne |
Dave |
Analog Air Cooled
Damn.. I have 3 SC ALTNs.
Voltage Reg same?
If you can find a spacer to make up the difference in height it will work. They're out there.
Analog Air Cooled
Is the VR the same? If so I can pop one off and into the other. Just don’t wannna pull it all apart.
Analog Air Cooled
