-   -   Name of switch (http://forums.pelicanparts.com/porsche-911-technical-forum/1115868-name-switch.html)
hughc 03-31-2022 06:05 AM
Name of switch
Can someone tell me the name of the blue switch in the area of the air flow plate on the back side of engine. I can't seem to find any reference to it in the Bentley
Thx
MBAtarga 03-31-2022 06:29 AM
Which make/model of car? I assume Porsche?
boyt911sc 03-31-2022 06:45 AM
Air Flow Sensor Plate Switch........
Thx
Hugh,
That is the AFS switch that supplies ground contacts for the terminal #85 @ FP relay socket and @ alternator D-. To get a better understanding how this switch works, use a continuity tester @ terminal #85 (FP relay) and a good ground contact. Raise the sensor plate and you will have an open line.
Tony
hughc 03-31-2022 07:41 AM
Sorry MBAtarga, I should have been a little more precise with that question.
hughc 03-31-2022 07:48 AM
Originally Posted by boyt911sc (Post 11651931)
Hugh,
Tony
Thank you Tony, I'm in the process of putting things back together on the engine and was unsure of the placement of the various black connectors in that area so by knowing the ID I can refer to the wiring diagram and confirm the color codes on each connector.
If there is a "next time" I'll be sure to identify each connector as I remove it.
boyt911sc 03-31-2022 08:23 AM
Wire color...........
Hugh,
Just make sure that the plug that goes to the AFS connector has 2 brown wires. The standard color for the plug is aqua blue. This particular plug for the AFS is the only plug in the engine harness that has 2 brown wires (no power source). Due to its proximity to CSV and AAR plugs people inadvertently mixed them up.
Tony
hughc 03-31-2022 12:55 PM
Originally Posted by boyt911sc (Post 11652056)
Hugh,
Tony
Thank you Tony, I got it all sorted.
I have one more question. There is a long wire with a female spade connector that is either bluish or greenish that I don't remember where it plugs into.
Can you help?
Thx
boyt911sc 03-31-2022 01:40 PM
Can you help?
Thx
Hugh,
Could you post a picture of the wire in question? Thanks.
Tony
hughc 03-31-2022 03:48 PM
Originally Posted by boyt911sc (Post 11652423)
Hugh,
Tony
I haven't mastered posting pics on the forum but I did send you a photo via email.
thx
hughc 04-01-2022 09:53 AM
thx
I think I found out where it belongs. It's a blu/wht wire and goes to the front of engine to the oil temp. switch.
Thx
