Name of switch
Can someone tell me the name of the blue switch in the area of the air flow plate on the back side of engine. I can't seem to find any reference to it in the Bentley
Thx |
Which make/model of car? I assume Porsche?
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Air Flow Sensor Plate Switch........
Hugh, That is the AFS switch that supplies ground contacts for the terminal #85 @ FP relay socket and @ alternator D-. To get a better understanding how this switch works, use a continuity tester @ terminal #85 (FP relay) and a good ground contact. Raise the sensor plate and you will have an open line. Tony |
If there is a "next time" I'll be sure to identify each connector as I remove it. |
Wire color...........
Hugh,
Just make sure that the plug that goes to the AFS connector has 2 brown wires. The standard color for the plug is aqua blue. This particular plug for the AFS is the only plug in the engine harness that has 2 brown wires (no power source). Due to its proximity to CSV and AAR plugs people inadvertently mixed them up. Tony |
I have one more question. There is a long wire with a female spade connector that is either bluish or greenish that I don't remember where it plugs into. Can you help? Thx |
Could you post a picture of the wire in question? Thanks. Tony |
I think I found out where it belongs. It's a blu/wht wire and goes to the front of engine to the oil temp. switch. Thx |
