1978 911 SC
Help identifying oil leak..
Yes this is a loaded question ... hah. Just had complete transmission rebuild, new clutch, main seal, valve cover gaskets and couple other small things. Still a small leak when sitting in garage and while driving. Seems to be on drivers side near the front of valve cover. Drips onto heat exchanger.. Any help on where to start looking, would be appreciated. Cheers.
1978 911 SC Complete rebuild, 83 engine, SSi’s M&K Sports muffler. |
very possibly rocker shaft-pin loose on cylinder no 3..intake or exhaust....
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I would check your oil return tube o-rings
1978 911 SC
Thank you for all the replies. Will look into the Rocker shaft pin & oil tubes this week. Matt, the head studs were just checked and all were good. 1980 911sc 3.0 motor. Again thanks guys !
